In most vehicles you have a range of between 40 and 50 miles after the light goes on. Don't experiment with that number or you are sure to be walking down the side of the road with a gas can in hand. Also, the gas pick-up tube in your gas tank does not go to the bottom as it would then suck-up any contaminants lurking at the bottom of your tank. When you run out of gas, there is still a gallon or two in the tank. You most likely did have 5 gallons left. Don't worry, your vehicle is normal.Singhman wrote:I was almost out of gas the other day (the light was on for about 15 miles). The screen said that I had 22 miles left on 'distance to empty'. I went to fill up and the gas pump began clicking at 16.3 gallons (the tank got full). However, the tank of a Murano is 21.7 gallons. that means that even though the light was on, and the needle was almost touching empty, there were still 5.4 gallons in the car? Does that make any sense? How can i accurately get MPG for my car?
