How To: 5 Speed Swap in Convertibles (and other S13s)
GoinTopless240
Car: 1993 Nissan Sil40 Vert
2008 VW GTI
2010 Infiniti EX35 bought in 2019 (15,000) miles
^ what he said..
SixMachine
Anyone re call the drill bit sizes to make the hole to put in the clutch pedal?
94_240sx
Car: 94_240SX
SixMachine wrote:Anyone re call the drill bit sizes to make the hole to put in the clutch pedal?
It's in page 8. I used 1 1/2 inch hole saw.zer...age=8
s13drob
Car: 90' s13 fastback
whats the fsm plug number for the park/neutral switch. and where does it originally run to when its plugged into the trans harness?
the only 2 wire plugs have a black & white wire (E18), and the other has a white & black/yellow wires (E19). also i have a chassis side wire that has a black/white and black/yellow wires that i have no clue go.
thanx 2 hijack for the email, he got it sorted out. incase others have the same issue its the black/white and black/yellow (E12) for s13 hijack is the boss
Modified by s13drob at 4:09 PM 1/16/2009
krillin99
there's a step by step article on doing a 5 speed swap in the january/feb issue of project car. it can be a good suppliment alongside this thread
leesredgt
Car: 1992 Toyota MR2 N/A
1991 Toyota MR2 Turbo
What is the gauge of the wire under the dash? That way ill know what size connects to buy.
Ken Park
Car: 1991 240SX
Can some of you guys please chime in on my thread:zer...98641
Basically, I have been using this thread as a reference, as I have an S14 M/T in my S13.
broke240sx
Car: 1996 nissan 240sx (no motor)
does any of this relate to an s14 auto to manual swap? anything?
broke240sx
let me rephrase that. does any of this info relate to the swap in an s14 i have a 96.
type-kt
Car: 240sx s13 93' convertible
I don't know if someone already asked I don't reallly have time to read over 10 pages.. but I dorpped my auto transmission theres this big cluster of wires alll attatched to the auto trans, and going up to the engine bay right behind the battery.. what do you do with these?? unpluge them all? cuz they are like hardwired into the transmission..
type-kt
your
broke240sx wrote:let me rephrase that. does any of this info relate to the swap in an s14 i have a 96.
you're in the wrong forum this is s13 convertible...or s13... there is a 14 one its a sticky but you have to click the right link
sijia10358
Car: '93 Nissan 240SX
do you guys know if you have to use 5speed transmission bolts or auto bolts are fine?!?!
darens13
Car: '93 240sx, '90 chevy 1500, '49 dodge pickup
the at and mt bolts are different lengths, i believe, so you will need the mt bolts.
marveezee
Car: '89 S13 FB
<Small>
<3 ty for this. my other forum is full of asswholes.
verted240
Car: 89 DOHC 5 speed coupe, 94 vert
have you herd of people using the auto's drive shaft and cutting it down?if you have, do you know how much to cut?
slim_240
hi i'm new to nico. i have a 91 240sx with super hicas. i'm currently in the process of converting it into a 5spd and also dropping an sr20. the motor set comes with a new wiring harness and ecu. the questions i have are:
1. would i have to go the whole re-wiring process even though i'm replacing the wiring and ecu? (btw when i was pulling out the motor, my friend thought it'd be a good idea to cut the chunk of wires above my firewall to get the motor out faster. would anyone know what it goes to? thanks)
2. instead of getting a clutch hard line, would i be able to use something like this instead? http://www.customcarscentral.c....html
sorry for all the questions! i tried to look for the answers all over the forum and couldn't find anything. thanks!!
94_240sx
Car: 94_240SX
slim_240 wrote:2. instead of getting a clutch hard line, would i be able to use something like this instead? http://www.customcarscentral.c....html
People use aftermarket clutch line because OEM hardline has been discontinued. Find hardline if you can. It works and fits better.
slim_240
thanks for the info! i'll keep my eye for a OEM hardline but i'll go with the aftermarket since i need the car running asap.
anyone know anything about the wiring harness?
thanks for any info!
350s15
Car: 1989 240sx
i did the swap like you said mine is not a drop top but it will not release the key and the lights in the dash stay on when you shut it off and the passenger side aft green relay buzzes the writing on my relay cover is gone so i do not know what the relay does if you disconnect the battery and reconnect the key will release and the buzzing stops and the dash lights go out i have the green box connected and the neutral safty switch spliced together i do not have the reverse lights hooked up is there something i forgot to do any help with this would be great thanks
240daveTX
Car: 2005 Nissan Titan LE
1993 Nissan 240SX Convertible
hijacker
im in the process of doing my rb20 wiring in my vert, it was auto prior to swap. i have the one plug jumped so the car will start, but from there im a little confused.
do i continue on with the rest of the swap instructions or do i need to modify mine with the rb wiring?
davidbekam907
Car: 1991 300zx
hi to all. i need all the necesary for this swap (the i have the 5 speed transmission ) any where can help me????
darkknight377
Car: 1989 240 sx, 1988 porsche 944 turbo , 1976 280z w/vortec 350(batmobile custom)
Sir, you are a true gentleman for posting this awesome tool.you saved me alot of time as i am doing a swap right now and just happened upon this post.
i thank you, my s13 thanks you and my neighbors thank you for not having to hear me cuss my car while i trial and error these fabrications.
cacaface
Car: 240sx 93' Conv with manual sr20
hello all, nice to see people are keeping this thread active. I need help getting my top to work with manual swap... I read everything, hooked up the brown/yellow to the green/blue taken off the back of the inhibitor switch and didnt connect them back to the inhibitor switch. It worked one time and stopped and I noticed recently my fuse is blown. The fuse on the kick panel drivers side, bottom right, 10. It's for the inhibitor switch....So i replaced that and it blew again. So i decided to disconnect the brown/yellow from the green/blue and fuses aren't blowing anymore. Any help would be so awesome. Sorry for such a long post, and if u need pictures let me know.
Modified by cacaface at 9:23 PM 5/14/2009
240sxConvert
Car: 1989 SR20DET Nissan 240sx
Hey 350s15, if your key is not releasing there is a plug underneath the center console piece with four wires by where the auto shifter would be...you need to just splice two of those wires...i am not sure on what the colors are but they are directly side by side...just get a paper clip and put it in both holes of the clip and try it. If the key releases then those are the two wires to splice together...
cacaface
umm, I decided to just hook up the brown/yellow straight to 12 volt source/battery, fried my wires quite nicely. The top did function though : ).I'm still at loss to why the brown/yellow is giving me so much trouble.
I went through my wires to repair them/replace and i noticed that my brown/yellow is spliced into the brown/yellow of the park/neutral safety switch plug. There's only one brown/yellow wire coming from, who knows where and, into my engine bay. Does that seem right?
Then the brown wire from the back of the inhibitor plug was spliced into the brown wire in the park/neutral safety switch plug.
Does any of that seem amiss? I'm searching around but I haven't succeeded in finding a good wire diagram that helps me. Sorry for such a bad question, but I've been working on getting my top working for a long time with no avail. Thanks in advance
cacaface
ermm, actually, can anyone just tell me where the Brown/yellow Wire runs to? Like from the back of inhibitor to... where? I think I will just try to jumper from that end if possible since something seems amiss (grounded) elsewhere in my lines. Thanks
1WheelWonder
Car: 1991 Nissan 240sx
Hey guys,
The 240sx Ive owned for the past 10 years came factory with a 5 speed. The 1989 Sohc 240 I just picked up was a auto. Ive got everything 100% in but cannot figure out which wire is the neutral safety switch but luckily i've got pictures so maybe someone can lend me a hand.
I don't use any of these 3 do I, there all auto related other than the reverse lights right?
Also, is it necessary to have inplace the two switches on the actual clutch assembly, reason I ask is that i don't see them.
I'd appreciate any help.
Modified by 1WheelWonder at 3:52 PM 6/4/2009
topless_240
quick question if i use a 5 speed upper and lower harness will I have to do any extra wiring?
topless_240
pretty please?
topless_240
Hey so I finished the swap but my speedo is not working, what could be the problem with that? I had to cut the wires off the speed sensor and resolder but I do have a speed sensor from an auto transmission with good wiring.
