How To: 5 Speed Swap in Convertibles (and other S13s)
my40
Car: 91 240sx
yeah def. a big help thanks.
numnutzzz
slownslurious wrote:94 240sx-you don't need the ECU the auto one works fine. You do not NEED the manual transmission harness, but it will make installation/wiring smoother (you won't have to splice anything). The reason so many people are talking about all this custom wiring is because they do not have the correct harness or chose to use a later transmission that isn't compatible with the s13 wiring harness. If you are pulling the transmission yourself and have the option to get the harness I would defintely get it, even if it meant paying extra, for all the wiring headaches it saves. But, if you just get the bare transmission you can follow the wiring instructions in this thread.
i actually have a manual harness. so my question is, since i dont have to splice ANYTHING, do you mean that the reverse, park safety, and my top will work just because i have a manual harness? if not can you tell me what more i must do if i have the manual harness?
Hijacker
Car: '92 240sx Convertible
'94 F-150
The problem with the manual sub harness is that the chassis harness won't work with it AFAIK. The auto chassis has specific plugs for the auto subharness, and the plugs are different IIRC.
All of the wiring I did was on the chassis plugs to make the top and reverse lights work.
P_856
Car: s13
do i need a backing/belhousing plate im not sure what you call it but it goes in between the engine and transmission
numnutzzz
Hijacker, i don't know how much to thank you. I would have never figured all these steps out myself. Thank you and everyone else who have left their feedback and opinions on this thread.
The wiring was the most difficult part to understand but after reading it over and over again it started to make sense.
numnutzzz
o yeah, i have a feeling i will be having a hard time drilling the hole for the clutch master cylinder. anyone has any special ideas on doing it without much headaches? my friend said to take the dash out but i don't think its a must do type of thing.
94_240sx
Car: 94_240SX
Use a drill like this.
whoflungpoo
Car: 2006 Infinity G35 Sedan
2003 Evolution VIII
numnutzzz wrote:o yeah, i have a feeling i will be having a hard time drilling the hole for the clutch master cylinder. anyone has any special ideas on doing it without much headaches? my friend said to take the dash out but i don't think its a must do type of thing.
don't take the dash out... if you do, you're going to be pissed when you realize that it clears up absolutely no room to work around.
I just crawled under there with my trusty dremel and cut out the center, and then used 18v ryobi and drilled the bolt holes, stepping up from small to large bits.
numnutzzz
thanks guys, this is one of them moments where you just think of your friend as a dumbass sometimes. hahahaha
Snott Rocket
Car: 1991 240sx, 1986.5 Toyota Supra, 1974 Corvette, 1962 Rambler Classic 400
Does anyone know if you have to use the dash harness to make the clutch interlock work, or can you wire it up separately? Thanks
Modified by Snott Rocket at 9:58 PM 1/12/2008
Hijacker
'94 F-150
The clutch interlock switch isn't needed. All it does really is cut out the cruise control when you push the pedal in. And even then, it's not really needed to make cruise work.
Snott Rocket
OK, cool. I thought it was to keep the car from starting with the clutch engaged.
Hijacker
'94 F-150
So long as you jump the park/neutral safety (the big thick 2 wire plug), your car will start. Even with the clutch engaged. Mixed blessing I suppose if you're not used to disengaging the clutch first, but you'll remember after you start teh caqr a few times with it trying to lunge forward.
Asmar
Car: 1994 Nissan Skyline
Dang... Nicely done!
numnutzzz
just finished my swap today. I'm calling it a night right now since it's almost 4am. i think i messed up on the wiring somewhere because it'll crank but wont turn over. I'll double check everything tomorrow. anyways could anyone tell me if i need those two plugs that i disconnect from my auto shifter? it's just hanging there right now.
Hijacker
'94 F-150
You don't need em. If you're cranking, then you did all the wiring for the lights and park/neutral switch right then. Go through, double check all of your engine grounds and go from there
numnutzzz
pretty hard to explain this but the engine does crank but it sounds like a howling noise. like the starter is having a hard time spinning the flywheel. its my friends motor so i was there when it was in the car and it started fine before we yanked it out. i highly doubt its the starter. i have three batteries at home and tried them all so i doubt its the battery. i'll check the grounds when i'm off work. any tips are appreciated guys. and thanks again Hijacker.
jtdomar22
Bart, Essex,Thanks for your support of this forum & this swap. With the help of the tutorial, I completed the 5-speed swap on my vert a few months ago. The B/U lights, top, clutch safety, and cruise all work properly, but I still have the high idle issue at stop lights. I have searched the forum severa; times and can't seem to find a definitive answer. Can you help?
My method to try to clean up & simplify the wiring was as follows:
--I looped the neutral start safety circuit through the clutch safety switch directly. Works great and takes care of the "starting the car in gear" problem.
--I ran the Park/top circuit through the shifter neutral switch on the 5-speed so the transmission has to be in neutral for the top to operate.
--The DRIVE circuit for the ASCD runs through the 5th gear switch on the transmission so the CC only works with the car in 5th.
--I didn't use any relays as I thought wiring direct was the simplest route.
The only issue is the high idle condition when I'm stopped. What causes this and how do I make it go away?
Again, thanks for your support of this forum. Any help would be appreciated.
--DOMAR
numnutzzz
welp guys, no luck at all. checked all grounds possible and it still does the same thing. cranks but it cranks with a loud howling noise. help anyone? i need to make it to a meet this saturday.
Hijacker
'94 F-150
JT, Have you tried adjusting your idle through the IACV located on the intake mani? Other than that, a leaky vacuum source can cause high idle.
Num, all I can think of is a bad starter. Is the start actually catching the flywheel and forcing the motor to try and crank? Or do you just hear a buzz when you turn the key? Since the starter is at least doing something, you have the wiring for the park/neutral safety switch done right. If that wasn't done, you wouldn't get so much as a relay click.
numnutzzz
wow pretty frustrating. i checked for spark and there's spark, i checked for fuel and theres crap load of unburn fuel in the exhaust. i seriously don't know what else to do now. this sucks. to put it to more detail, the starter spins the flywheel but it makes a loud howling noise and i also hear a high pitch screetching noise.
Hijacker
'94 F-150
This problem is going outside of the scope of this thread. I would recommend starting a "WTF Mate" thread in 240 Tech to get some replies. From the sounds of it, there's something wrong with the motor or the motor install (you make it sound as if you swapped the whole motor and trans together). Plus diagnosing a weird sound over the internet in text format is very difficult unfortunately
numnutzzz
yeah i did swap out motor+trans together. i'll start another thread, sorry about that.
plus, if i swap out motor+transmission together, there's nothing more to do in the wiring or timing right?
numnutzzz
question: if i am swapping engine plus transmission together to convert auto to manual. do i need to use the manual engine harness or auto harness? because on a manual engine, the Throttle Position Sensor does not have a wire connector attached to it, but on the automatic, there's a wire connector connected to it.
Hijacker
'94 F-150
I typically use the manual EFI harness.
94_240sx
Car: 94_240SX
Goldeneagle wrote:If anyone is wondering what sized hole saw to get. Buy a bi-metal 1 3/4 inch hole saw.
I personally bought a 1 1/2 inch hole saw due to budget constraints and then used a dremel to remove what I couldn't with the hole saw.
1. Is this true? I measured the cylinder and it's slightly smaller than 1 1/2, so I would think 1 1/2 inch hole saw will work. I need to know this ASAP.
I have some more questions:
2. I have B&M short shifter. Should I install short shifter before or after swap? I like to install it before, but I'm getting mixed responses. If I can use fill hole to fill the fluid, I can install it beforehand, right?
3. I'm going to use Redline MT-90 fluid. Should I add any additive in there? Like Lucas oil stabilizer and such?
4. I have ECU from manual s13. Should I just leave auto ECU or swap it since I have one? Or it doesn't matter what I do with ECU?
Thanks!!
biggie
Thanks!!
Its been a while since my old coupe was done and haven't gotten to the Vert yet but...
1. Not sure2. I'd install it before the transmission goes in if possible, depends on your installing situation. If you have the room to install the transmission with the shifter on it, then install it first.3. MT-90 by itself has worked well for me.4. Can't remember exactly, but I'd think you have to switch the harness to a manual harness to use the S13 manual ecu. If you have it and are able to I would use the manual S13 ECU, the AT one did bug me a little with the idling.
94_240sx
Car: 94_240SX
Thanks, biggie!
1. I'm drilling the hole tonight, so I need to know. Someone said 1 1/2 and someone else said 1 3/4, so... Clutch mounting bolt holes are 3/8.2. I guess I'll install it afterward. I think it's going to be easier that way.3. Got it. MT-90, but I saw someone mentioned about adding Lucas oil stabilizer somewhere.4. It's a direct swap without any modification as far as I know, so I'll just plug it in then. Good thing that I got it with a transmission just in case.
94_240sx
Car: 94_240SX
I have a question about speed sensor. Are s14 and s13 speed sensors interchangeable? Will it plug into the hole without any problem? I'm trying to find s13 speed sensor for my s14 transmission and want to make sure it'll work. I have s13 and transmission is from s14.
numnutzzz
i remember seeing someone mention something about their speedo not working after the swap. could someone give me some info about that? i've searched these 7 pages but couldn't find it. i must be blind.
