viciou5240 wrote:wut if i part out the s14 and do da conversion swap in the s13....is this possible..??? and if so...wut do i need..???
I think you missed what IslandStyle posted on page 5. Yes, it's possible and this is what he said. I also bought s14 manual transmission. Junkyard had s13 and s14 transmission. s13 transmission had leaks all over the place, but s14 transmission shifted smoother and clean, so I got that one. I did some research before I bought it and learned that s14 would fit on s13 with no problem.
By IslandStyle ---------------------------------------------------------------I want to update some info that wasn't in this thread due to the combination of parts that I used which other people WILL run into. My setup was an S14 transmission from a 1998 with an S13 driveshaft. This isn't uncommon since people will go for a later transmission due to lower mileage.
You'll run into 2 problems though that are easily fixable. First off is that the speed sensor for the S14 has a female plug that is built onto the sensor, it is not a running male wire like the S13. AND, the speed sensor for the S13 is different and WILL NOT fit in the new S14 transmission. So you CAN use the S14 speed sensor, but you need to cut the harness off of the S13 sensor, and splice the black and green wires to the pins on the S14 sensor. If you hold them side by side, they two wires are configured the same, I believe it was green on the left, black on the right. But it works fine.
Secondly is the transmission. It is the same transmission as any of the years for the KA24DE, but the S14 has a large black ring around output shaft the gets in the way of the bolts on the end of the driveshaft. Although it may be tricky, the piece slides right off. I hacked it, drilled it, bent it with pliers and when I was halfway through it with the hacksaw it just popped right off. So I guess you could probably just hammer it off.
