How To: 2011+ M37x Eibach Install, DIY
MY2J
Car: 2011 Infiniti M37
I installed my coilovers this weekend and ran into a small issue. When removing the rear shocks from the axle, one of the nuts is welded directly onto the shock... the BC coilovers did not come with this "extra" needed nut. Luckly I have tons of nuts and managed to find one that fit perfectly. Just an FYI to anyone who installs theirs.
OEM welded nut
BC no welded nut (nut not provided)
wideopn11
Car: 2012 Infiniti M37x Moonlight White
Takeda CAI
Stillen exhaust w/ MeganRacing Y-pipe
SCALE coilovers 16K/10K F/R
Akebono BBK
Cusco strutbar
25mm spacers F/R
Uprev tune by seymore4
That's interesting; they didn't provide hardware for the new coilovers? Anyone else have this issue?
ssmrico
Car: 2011 Infiniti M37 S
yeah when I got my coils which are still just sitting inside my i30 the guy told me about this and provided me the nut he had used for his , weird they don't provide it
CRV_33
Car: 2011 Infiniti M56x
wideopn11 thanks for re-hosting those photos and its getting my confident that I can remove the rear seats quickyl and its give me some ideas on how to route the rear damper extenders
wideopn11 wrote:That's interesting; they didn't provide hardware for the new coilovers? Anyone else have this issue?
ssmrico wrote:yeah when I got my coils which are still just sitting inside my i30 the guy told me about this and provided me the nut he had used for his , weird they don't provide it
-Thanks for pointing this out ssmrico. Did the guy just provide a standard nut?
-wideopn11 - I just got my coilovers from Scale and the bottom forks doesn't integrate or include the nut either.
ssmrico
looks like it
wideopn11
Takeda CAI
Akebono BBK
Cusco strutbar
25mm spacers F/R
@RED_DET, any thoughts on the rear suspension needing a nut? Is this something you could inquire about directly to the vendor?
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
Looks like the the image of the BC installation are used coilovers. Was that a brand new kit being installed? On brand new kits the nut is usually zip tied to the bottom fork/mount in the applications I have seen in person, to include M37 and G37 coilovers.
CRV_33
Scale Suspension does not include that nut. You can get the nuts at any local Nissan/Infiniti dealership for a $2/ea (part # 01225-00072). If you're in a dire situation any local hardware store will have it as well. M12 1.25 Pitch (fine thread).
DubXSY51
Car: 2013 Infiniti M37X S (Y51), former owner of 2006 M35 (Y50)with tech package, 2002 Maxima, 2000 Maxima
Thanks for the info...looking to install some coil overs soon.
wideopn11
Takeda CAI
Akebono BBK
Cusco strutbar
25mm spacers F/R
CRV_33 wrote: -wideopn11 - I just got my coilovers from Scale and the bottom forks doesn't integrate or include the nut either.
How do you like your SCALE coilovers? What springs and rate did you go with? Any other options like pillow ball mounts or stainless hardware?
wideopn11
Takeda CAI
Akebono BBK
Cusco strutbar
25mm spacers F/R
Pics 99% updated for Eibach install. Look for a new write up on SCALE coilover install soon.
wideopn11
Takeda CAI
Akebono BBK
Cusco strutbar
25mm spacers F/R
Updated with simpler/easier front method.
splitnails
Car: M56
Installing my springs this weekend. Hope I don’t screw it up! I’ll be following this how to. Thanks again for posting this!!!
Purenv
Car: 2012 Infiniti M37x stormfront gray
I want to do the Eibach springs also but was told by Eibach that the RWD springs were not guaranteed to work with the AWD M37. Thank you for showing me it can be done and looks grea! I have just a question for you. With regards to your Eibach springs install, did you need any other parts to get the car’s suspension in spec for alignment?
wideopn11
Takeda CAI
Akebono BBK
Cusco strutbar
25mm spacers F/R
I never had any issue with the Eibachs; maybe a slight negative camber but that's to be expected and welcomed. Nothing that would require adjustable arms or camber plates.
JCesar
I have a few questions regarding the Eibach springs. i want to get them for my M37x but what is the ride quality like compare to the factory springs? do they feel about the same as the stock one? I don't want to lose on the comfort side
stm37s
Car: '12 Chrysler 300 SRT8
'11 Infiniti M37 S
'06 Range Rover HSE (Wife's)
'12 Chevy Camaro LS (Wife's)
'95 Chevy Impala SS (sold)
'04 Chevy Impala SS (sold)
'12 Hyundai Veloster (Daughters)
JCesar wrote:
Sun Apr 08, 2018 6:22 pm
They fill just like stock if you have an m37s, firm.
I had the eibach springs installed on my m37s a while ago and they were ok, but still had too much spare between the tire and fender wheel for me and I went with BC coil overs.
wideopn11
Takeda CAI
Akebono BBK
Cusco strutbar
25mm spacers F/R
The ride quality on Eibachs is good, it's a progressive spring so it gets stiffer the more you lean on it in the corners but initial bumps in the rode it's only slightly firmer than OEM. Like others though I also wanted more low so I switched up to SCALE coilovers.
archo
Car: 2011 M37X
did you have any camber issues with this? recommenced any bushing etc that i should change out when installing the springs while I'm in there? thx!
wideopn11
Takeda CAI
Akebono BBK
Cusco strutbar
25mm spacers F/R
archo wrote:
Mon Feb 04, 2019 6:19 pm
Not really. A little negative which was good but nothing that needed attention. Bushings are a pain in the @ss. I had to replace one that was damaged. Unless one is damaged or you just really want some solid spc bushings I wouldn't bother.
JuniorHernandez
Car: 2011 Infiniti M37x
Can RS-R rwd lowering springs fit to a awd shocks for a 2011 infniti m37x?
