sxxy1992 »
https://forums.nicoclub.com/sxxy1992-u48078.html
Sat Oct 28, 2006 8:57 am
Yes, that's right. looks like we are driving the same animal.that being known, here's some steps to get it out where you can hold it in your hand.A. You should probably remove the negative terminal of your battery or pull the fuse for the antenna.1. Remove carpeting from the left side of the trunk area. just fold it over is fine.2. put a screwdriver blade under 2 plastic poprivets that hold the plastic side trim on the left side of the trunk inside. that way you can fold it around clockwise and expose the metal sidewall of the trunk, jack access, bolts, etc. You can use a screwdriver and just pop them out. they are a hinged sort of thing that stays put but comes out fairly easily.3. Remove the jack. Look in that area and see if you have wiring that is draped over the forward lip of the jack holder. If so, fix that problem later on also.4. There are 3 bolts in a triangular pattern to remove from inside the trunk for the jack holder. Remove the jack holder.5. Just inside the cubby hole for the jack and above, you will feel the connection for the antenna wire. It is only about 12"long and curls up to the antenna itself. You need to disconnect it there. Take the main wire now and where it is attached to the metal wall of the car there is a white poprivet sticking from the inside to the trunk space itself. You will see just a little white pop sticking thru. Pinch it together and pop it back into the cubby hole as you will probably have to pull it out from the main wiring of the antenna. I'm just saying pull it inside the main trunk area to free up all the wiring of the antenna it may be threaded thru. And then just let it hang there as shown in the picture. Make sense?6. Now there is a cap (metal) ring that screw on to the top of the antenna that keeps it tight to the car itself. It has 2 tiny holes on either side of the ring. I used the ends of snapring pliars and put them into the holes and very gingerly assisted the tool in turning counterclockwise and helping it ever so gently to turn and not breaking the ends of your snapring pliars. It will begin to move and just screws off. Put it to the side.7. Now remove the plastic "bonnet" affair that is on top of the car above the antenna. It just lifts off but you should mark it as far as location (pencil mark facing to the front of the car, etc.)8. Now the only thing holding the antenna inside the car are 2 shiny bolts forward of the 3 you removed for the jack holder. Remove these bolts and be holding onto the main unit with your left hand inside the cubby hole area as you are removing the last bolt. It will come away from the wall easily and will be in your hand. Now it is up to you how to get it out from that area. On the bottom of the unit there is about 15" of rubber tubing and I believe the nylon tail from the antenna draws up and retracts inside that tube. Just so you know that it is there. It just needs to be placed back along the bottom of the cubby hole so the tubing is free and clear and able to do its thing.9. I believe I dropped the unit straight down deep into the cubby hole and there was more space to just snake it out into the trunk. You are coming out of the jack access hole, you understand. It is best to tape the plastic trim stuff to the tailgate so it won't be in your way. Should work ok. Just somehow get the motor and antenna combo out of the inner fender without ripping the wiring from the unit. Remove the wiring after you get it out.10. Now that it is out, on the larger electrical plug, push in on a small lever of the plug and the plug will pull right out. I used a small bit of silicone to coat parts of the plug for reinstalling and if I need to remove it again. Then remove the little 1-wire electric plug. Next and last, push the tines of a large tan plastic clip to the sides and remove the shaft of the antenna from this clip that is attached to the smaller wire loom. Put the plugs to the side and you have the antenna and motor combo in the palm of your hand. Just reverse the process exactly and attach the power at the finish. Simple as that. I sure hope this helps you and let me know if things go bad.
