rb25drag »
https://forums.nicoclub.com/rb25drag-u76935.html
Tue Aug 12, 2008 3:39 pm
I have Approx 320WHP, and I ran 14 track passes on Stock 18 year old axles with a welded Diff before I broke not 1 but Both of them at once on a Launch, No wheel Hop, Just Snapped the ends right off them. I bought an Aftermarket set Stock, and have been 17 passes with no problems so far, BUT, I have not had good traction either, only cutting 1.7-1.8 60', I should be in the 1.5's with stickier tires.
I broke mine on a set of MT Et streets, 26x11.5x17's, I think with a MT 26x8.5 you won't break them as long as you don't do a 6,000 RPM clutch drop. It is all in how you launch the car. I personally was launching at 6400RPM's when I broke them, I have installed a 2 step since then and now leave at 5500RPM, and have not had any issues, I think you will be fine on your stock ones tho.
