jdmfreak03 wrote:What are tensile loads?
Tensile loads are forces that pull on an object. Compression loads are forces that push on an object. Engine components can handle compression loads much better than tensile loads. Basically, when the piston pulls on the rod, that is a tensile load. When a piston is reaching TDC, the tensile loads are highest, because the piston wants to keep going up, so it pulls on the rod, and that's how it slows down. When combustion happens in a cylinder, the force pushes on the piston, and causes compression loads. The tensile and compression loads are acting in opposite directions, so they sort of cancel each other out. This is why you can turbocharge an engine, and double the stock horsepower without blowing up the engine, because it can handle the increased compression loads. However, if you tried to double the horsepower by just spinning the engine to higher rpm's, you would blow the engine because the rods would not stand up to the high tensile loads. That is why, when an engine is revved way too high, it often snaps a rod in half.
That's basically the short explanation. Corky Bell goes into some pretty good detail in "Maximum Boost." You should read it.
