How stout is the engine / transmission?
justjuiceit44
What got me thinking about turning this car into a sleeper was this:http://cgi.ebay.com/ebaymotors...&rd=1Obviously the car would need a full tune-up including timing belt and transmission flush (which would not be too hard for me to do the work, since I am an ASE-certified). The bad part is that it also needs front and rear shocks/struts: I know exactly why since I drove in that area during Christmas (roads are brutal!). The super low mileage concerns me also, since they may have only changed the oil once a year.
Modified by justjuiceit44 at 10:19 AM 1/28/2008
gr8scott72
Car: 1994 Infiniti J30t
justjuiceit44 wrote:What got me thinking about turning this car into a sleeper was this:http://cgi.ebay.com/ebaymotors...&rd=1Obviously the car would need a full tune-up including timing belt and transmission flush (which would not be too hard for me to do the work, since I am an ASE-certified). The bad part is that it also needs front and rear shocks/struts: I know exactly why since I drove in that area during Christmas (roads are brutal!). The super low mileage concerns me also, since they may have only changed the oil once a year.
I think I would pass on a 15 year old car from NY. Too much rust for me.
justjuiceit44
Too much rust for you?! Then you would have had a heart attack if you would have seen my 1976 Suburban that was in Michigan its entire life! After 30 years of salt and moisture, the amount of rust on the body, exhuast, and frame probably weighted more the entire J30! In fact the first day I got it, I was moving a bunch of stuff and was opening and closing the doors a lot. I think I had a weight reduction of about 100 lbs from all the rust the came off!
gr8scott72
justjuiceit44 wrote: Too much rust for you?! Then you would have had a heart attack if you would have seen my 1976 Suburban that was in Michigan its entire life! After 30 years of salt and moisture, the amount of rust on the body, exhuast, and frame probably weighted more the entire J30! In fact the first day I got it, I was moving a bunch of stuff and was opening and closing the doors a lot. I think I had a weight reduction of about 100 lbs from all the rust the came off!
We are spoiled down here. (Mississippi) We got our first snow in SEVEN years 2 weeks ago and that didnt' even stick to the roads, just a couple-three inches on the ground/cars.
brandonjustice93J30
Car: 1993 Infiniti J30
I'll be more than happy to send the snow that's on it's way here... down that way...lol
yodawill2000
Car: 94 Infiniti J30
Snow ???Whats that ???
brandonjustice93J30
yeah, yeah...forgot you dont know what that is either..lol
