corey240 wrote:or i got all the fluids draind from my motor. its a rdtop sr in an s14 if it makes a diffrence. i got most of th plugs un done just gota do the lowr plugs and the rar heatr hoss and its ready. now the problem is that the car is sitting in a yard. i hav now way of moving it. should i get the car on jack stands and unbolt the transmission from the motor and just pull the motor? or should i pull both the motor and trany out? i honslty dont know what i should do on this part. all im doing is checking the head for cylinder or piston damage. any help would b appreciated,
Why are you pulling the whole motor out if you just want to check the head for damage? Save yourself the time and effort and just get the head off. If you still want to pull the motor out, get your hands on an engine crane and just lift the whole engine and transmission out together as one piece.
Make sure you check for anything that might still be connected. Everytime that I pull stupid motors out I always seem to forget about a ground wire or something else. If you start lifting the motor and it seems stuck, stop and check to see what is holding it up.
