themadscientist »
https://forums.nicoclub.com/themadscientist-u2806.html
Sun Jun 19, 2005 6:45 pm
for what you want in the short term IMO you should do the minimum to get the car up and running. It has been my experience, and yours too from the look of it that projects quickly spin out of control and you fun out of money. I hate hearing about these guys who save up just enough to get the engine and then something like this happens, they are tapped out and their car becomes a lawn ornament while they go sell blood to buy parts. Unfortunately it seems to be more the rule than the exception.You do not need head stud and solid lifters to reach 300hp reliably, 400+ and you should get them. The stock head bolts are fine it's just nice to overengineer and get some "oops" insurance. I have run several RB20DETs up to 250(dyno confirmed to the wheels) doing nothing more than;
1. starting with a healthy motor, properly maintained with good compression.
2. complete tune up; plugs, dressing the coil tips, set timing and idle, clean the AFM and throttlebody, new fuel filter, pop the cover off the plug valley so the coils can breath and mount the igniter box up on the firewall, reset the computer, pull the OEM SMIC and flush out the inside and outside as well as straighten the fins, same thing for all the intercooler piping, backflush the cooling system and clean the business-end of the radiator.3. Get the air in and out, high flow air filter (I prefer HKS power flow), aftermarket downpipe and muffler and punch the cat(sorry PETA). I replace the OEM BOV, it can open when you up the boost, kind of defeats the purpose.4.Add fuel, I have used things as complex as a single, five or supe AFC to simple as adjustable pressure regulators to straight ghetto, hose clamp on the fuel return line.5.up the boost, the RB turbos will endure settings of 0.9 bar without doing damage, past that is a bad idea.
this is the "basic light tune", good for a reliable 250hp
Were I to want more I would reccomend;
1. bigger turbo, an RB25DET or VG30ET OEM turbo is a great upgrade and a tubular outlet is a very good investment towards reponse and peak flow.
2. more and smarter fuel, the stock RB25DET injectors flow 370cc, you should have at least that CA18DET 370s but I would reccomend more for growth potential like RB26DETT 444s, 13B 450s, or 13BT 550s. You need a bigger pump to feed them reliable, GT-R or maybe an FD3S(not sure about the compatibility, I am speculating about the 7 pump). Ghetto fuel control has to give way to a minimum SAFC with high and low maps.
3. Get cold, time for a bigger and more efficient intercooler. For the RB20 and 25 I prefer "switchback" intercoolers where the outlet points back across the top. With the RB's intake it's the shortest route, the "passthrough" ones have to travel a longer distance to the intake. Whichever one you can get will be good, I just prefer that type. Replace the radiator with a better one, 20s run hot and an OEM GT-R radiator is just good enough, get a full aluminum one if you can.
This is the basic "medium tune" on the same healthy motor, should get you a reliable 300hp. You could get a metal head gasket but a cool-running RB under 1bar should be fine, I would hold off until it's time to get stupid.
The 300+ build is where we part company with the stock RB20 IMO. I would do a complete engine overhaul with forged pistons, mountain cams, solid lifters, $1000.00 oil pump, $300.00 head gasket, studs, standalone engine management, basically "the works" It is a little overkill in some areas but I am generally lazy and paranoid and don't like doing things twice. I don't want to have to go back in there so if I want 400hp I would build it to handle 600 because **** happens and can't afford for **** to happen ya know?
In your situation however I would assume the worst. Assume the motor and head you have are on their last legs and just do what it takes to get it up and running. If you really and truly want a strong realistic motor I would get this one back together as best as you can and get your car back on the road. If you still have the KA keep it in the corner for a backup and save your money for the buildup on the RB so when you go to do it you can do it to your satisfaction without cutting corners or doing things "good enough". You will be happier.
