Ubernoober »
https://forums.nicoclub.com/ubernoober-u14357.html
Fri Dec 31, 2004 11:58 pm
I live close to you (the Valley) and it gets way hotter here than where you are. I don't know that you will need to give the rad direct air. Sounds like additional work just for the sake of additional work. Cool if you are going for style points though. Here is what I would do...Front mount the IC, close up some gaps around the stock rad to make sure airflow is good, then sidemount the transmission and oil cooler.BTW, I think a transmission cooler is ok (automatic eh?), but why the oil cooler? Oil must come up to temperature to do its job as designed, and almost ALL the ghetto oil kits do NOT include a thermostat or bypass, which means they frequently overcool the oil. Nothing good there. Not only that, you are adding a great place for an oil system failure and particle junk to collect. Unless you are on boost hard 70% of the time or more, I don't know that an oil cooler will benefit you.
I would like to see others opinions on an oil cooler, since I am hardly the last word in engine building.
