fxjackso »
https://forums.nicoclub.com/fxjackso-u250.html
Fri Oct 24, 2003 4:11 pm
The rear end jump may be a problem with the rear pressure control unit, but it is an annoyance, not a major problem. Ignore it.
You can DIY the accumulators. You can also do it in stages. As you have read, there are nine. They have different functions.
Each strut has a small accumulator. It's purpose is to absorb bumps quickly. There are also 5 other units (main and pressure control F&R, and one by the pump) that are used to store up pressure so the system can act quickly when the sensors detect a bump, or dive, squat, or cornering "G" force.
To completely rebuild, you'd need to be sure all 9 are charged. To smooth the ride, the four strut accumulators, which are on the actuators, are a start. The next three restore the ability to control the car, and the 2 small ones, the least crucial, speed up the reaction time slightly.
When all are working-amazing!
Keith Bowers (Texasoil) recharged mine, and I installed them. It's time consuming but not difficult. You will appreciate the system even more when you see the quality of the assemblies.
