Jeff Williams »
https://forums.nicoclub.com/jeff-williams-u431.html
Thu Jun 29, 2006 1:26 am
Ross, welcome!
Once you start posting, beware!
The Q is very well-engineered, and thus, intuitively assembled. There are more screws and bolts in most parts, but not quite a terrible as the Germans. The Japanese were still budget concious at the time.
The engineering put into the drivetrain is quite impressive.
Definitely get the FSM. Shoot me an email, and I can burn you a copy. Print out the 900+ pages, and put each section in a separate binder, for ease of use.
Don't bother with the EXPENSIVE Consult. Most diagnostics can be done on-board. Get to be friends with the local Infiniti service writer and technicians. A $20 here and $20 there will get you free diagnostics when you are stumped.
NEVER act like you know what you are talking about on the forum. There is always somebody reading that knows much more than you do. Eventually, you will type something that isn't true, and you will be blasted for it.
Always give away your spare parts to another forum member.
Post before you do a job, then post afterwards. We like to read about others troubles and issues. More than likely, one of us had been through the same thing, or are about to embark on it.
When you are searching, search archived posts here, the Infiniti Online Mechanic forum, and in the Infiniti General forum. Read the articles and browse Q45.org
Welcome, "Save the Q"
