https://lh4.googleusercontent.com/-X1fu ... 2%2529.jpg
Yes I really did do this a few hours ago. I got lazy on the front toe I know it should be zeroed out.
Will do! nearly every rubber piece is coated with silicone grease.elwesso wrote:I'd check the lower control arm bushings.
You mean play when shaking the wheel up and down? Side to side has to do with inner/outer tie rods.elwesso wrote:The important part is really that it's good side to side.
elwesso wrote: The thing that's interesting is that the camber is high all around, sort of seems like the car is riding too low like the springs are sagging? It's odd for it to be off all roughly the same.
