how rich will the CA run?
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
i was just thinking today, how low can that air/fuel ratio be before the car wont run? mine ran fine at 6:1 and now is even worse due to not being tuned yet. i can literally watch my gas gauge go down when im driving it. i drove 15 miles last night and managed to use a quarter tank of gas. has anyone had theirs run with an air/fuel ratio lower than this, or am i just "special"?
by the way, the car runs like a swiss watch
- tim
RMiller
Car: BBQing
Mine's too rich to run! Haven't checked ratios...(duh). But that's because my injectors never, ever close with the ecu plugged in. WTF? That's why I'm getting an SDS.
NeedCAforS13
Car: CA swapped S13 coupe
mine runs pretty rich too... my rear bumper is getting pretty black right around the exhaust tip. I just picked up a new o2 sensor though, so we'll see how that works!
Sean
8ggalant
Car: nissan cefiro
NeedCAforS13 wrote:mine runs pretty rich too... my rear bumper is getting pretty black right around the exhaust tip. Sean
same here...and the previous owner said he just replaced it so heh...its not puffin too much now...
themadscientist
fix that! My Toyota fried the computer and ran at around 10:1 for over 2-years. Over time the cylinders being washed down with fuel cause scoring in the cylinder walls and a car that could hang with a stock RB20DET Skyline could now barely pull itself up a hill. Fix your mix
pulsar gtr
Car: NISSAN VEHICLES
O man, you want to talk about your car running rich, You should see and smell my car, I can refuel another car through my exhaust, I should of taken boost_boys advice and get a standalone ecu isntead of going through JWT, with My stock injectors 370cc, jwt program was pretty good, but now having 550cc injectors, dam, I don't know what to say, I guess I need a bigger fuel tank lol.
I am in the process of doing a full rebuild on a RWD engine as well as I will convert it to FWD and replace the ca18det that is currently in my car, but depending on the Funds, I am hoping I can get a standalone some time this summer.Few people around here have beeing using the SDS system and I only heard so far nothing but good feedbacks.
PULSAR GTRRafi
r34 gtr
haha, good to know im not the only one. if you hold your hand in front of the exhaust outlet in my car, your hand gets wet with fuel. i leaned it out considerably today and its not doing so badly. i hope to get it tuned sometime in the near future.
by the way, i managed to blow my intake side valve cover gasket today.... oil leaking out the back and down the bell housing onto the floor. its really gay. i can use the ca18de fwd valve covers, right?
- tim
pulsar gtr
R34, how on earth did you blow your valve cover man, do you mean the valve cover gasket?And yes you can use the Valve cover from FWD, if you want one, let me know, i have few of them, I can send you one.
Actually, I might have a RWD one if you want it, let me know, I will try and find itPULSAR GTRRafi
pulsar gtr
R34, I miss read your thread and yes, I see you blew your gasket, I was shocked first to hear that the valve cover actually blew but that is me miss reading your thread.Yes, the FWD gasket will work fine and it is identical.PULSAR GTRRafi
rico05
Car: 1992 RMS13 w/ CA18DET
Mine runs slobbery rich as well. I am installing some hardware as soon as my fittings come in to hopefully rectify that.
RMiller
Car: BBQing
pulsar gtr wrote:R34, I miss read your thread and yes, I see you blew your gasket, I was shocked first to hear that the valve cover actually blew but that is me miss reading your thread.Yes, the FWD gasket will work fine and it is identical.PULSAR GTRRafi
I still want to know how he blew the valve cover gasket. WTF, it's like oil under there and the gasket is rubber. How does it blow? I can see it leaking, but that'd be when I unbolt it, clean it and bust out my big supply of RTV and slap a nice bead on there. That is unless the rubber is dry-rotted or turned to dust .
WeldingHank
Car: 1989 240sx CA18DET
dynoed my CA yesterday, the CA seems to like it rich. i would make more torque and it would come on earlier if i tuned it to about 11.1 A/F.
r34 gtr
i dont know how i blew it out either. i just saw oil leaking onto the floor and traced it up the back of the engine. it looks like the gasket blew out at the back, spraying oil all over the firewall. it only leaks when the engine is hot and it isnt a very big leak (just that under pressure things happen more quickly..). anywho.. that gasket was a little past its prime so if you want to send me one rafi, it would be awesome. just let me know what i can do to pay you for it. if you take paypal thisll be really easy. thanks man!
oh, and ill take a picture of the gasket when i can, just to prove that it can be done, haha.
- tim
NeedCAforS13
Go to Nissan. Order a CA18DE puslar gasket for less than $10. Go fix your $hit.
damn.
Sean
r34 gtr
well, i would but since i have to go back to school today time isnt an issue. i wont be able to work on it for another 2 weeks. hopefully i can have it done then. damn this is taking forever.
- tim
pulsar gtr
HI Tim,
I thought you want the Valve covers, but instead you actually need the gaskets, I do have two used ones that I had them on for about a month which I removed due to work that I had to do in the head and I always use new ones when ever I can, but if you want them new, I can also get them for you, they are about $12 each which I do recomend to replace your half moon piece gaskets as well, they are cheap about $1.5.
If you want the used ones, just email me your address and they are yours man and obviously no charge as they are used. [email protected] and if you want the new ones, you can paypal me to the same address and You will pay for shipping upon receiving them.
RafiPULSAR GTR
r34 gtr
ah, its cool. ill just order them from nissan. while im waiting for them to come in i can wonder how the hell i managed to blow one of them.
- tim
wildacexxx
Car: 2002 Q45 nav sport
u sure its not the MAF r34?
float_6969
All this tuning talk is making me itch for my car...
wildacexxx
so scratch the itch and get her running!
float_6969
Waiting on parts bro. If I'm feeling rambuncious, I could put it in this weekend. We'll see though...
