HOW REPLACE REAR WHEEL STUDS
machuelo
I LIKE TO KNOW THE PROCEDURE TO REPLACE THE REAR WHEEL STUDS
Td5turbo
Car: S13 Silviaaaaaa
1. jack up the car2. take off wheel3. put car on jackstands4. screw a lug nut about halfway on5. spray stud with WD-40 or other loosening agent6. smack the crap out of the lug nut with deadbolt hammer7. remove lug nut once stud breaks free8. pull out stud9. put new stud in place10. place a spacer between the hub and end of stud so the lug nut doesnt bottom out11. put lug nut on what threads are exposed past the spacer12. tighten lug nut to pull the stud in13. once the stud seats, remove lug nut and spacer14. put wheel back on15. remove jack stands16. lower car17 paypal me some money.
Acecool
Car: 1989 Nissan 240SX Hatch Pig KA24E 126k
18 Press shift or caps lock key to turn off the [A] light on your keyboard :-)
unwed_transient
Td5turbo wrote:1. jack up the car2. take off wheel3. put car on jackstands4. screw a lug nut about halfway on5. spray stud with WD-40 or other loosening agent6. smack the crap out of the lug nut with deadbolt hammer7. remove lug nut once stud breaks free8. pull out stud9. put new stud in place10. place a spacer between the hub and end of stud so the lug nut doesnt bottom out11. put lug nut on what threads are exposed past the spacer12. tighten lug nut to pull the stud in13. once the stud seats, remove lug nut and spacer14. put wheel back on15. remove jack stands16. lower car17 paypal me some money.
hahaha, what's up man? you haven't posted on 240sxforums for awhile. how's sc treatin' you? still got teh red s13?
180fan
Car: 89 fastback
bleh, thread a lugnut onto the wheelstud and take a hammer to the lugnut. it'll pop out after 2 or 3 strikes tops.
get 4 or 5 m12 washers and stack em up. thread the lugnut on the stud and turn till it pulls in all the way.
machuelo
thank you if I fix Ill giveyou some tip
Kornkidz
Car: 1990 240 SX
hey i need to replace my studs also im real lost. am i supposed to remove that big bolt in the middle? or should i start to smack the wheel studs??? it seems tought as heck to break them out it feels as if i should be taking something off...
adrianfromthecastle
Car: 1992 Nissan 240sx
Kornkidz wrote:hey i need to replace my studs also im real lost. am i supposed to remove that big bolt in the middle? or should i start to smack the wheel studs??? it seems tought as heck to break them out it feels as if i should be taking something off...
nah, you dont need to remove the middle bolt.
Acecool wrote:18 Press shift or caps lock key to turn off the [A] light on your keyboard :-)
but then that would disable the "yelling" implication lol
ddgsxr504
Car: 1995 Nissan 240SX SE 2007 Infinit M35 Sport 2011 Nissan Pathfinder Silver Edition
180fan
Car: 89 fastback
those studs are easy to smack off. just thread a lugnut and smack with a hammer. easy. done.
