how reliable is this setup? (sr20)
panda240sr
Good afternoon. I am looking to buy a 240sx with an sr20det and was wondering hoe safe and reliable is this setup the current owner is running.
S14 SR20
UPGRADED RS3871 TURBO
ISIS TURBO MANIFOLD
3"TURBO ELBOW
3"DOWNPIPE
3"TEST PIPE
3" MIDPIPE AND CATBACK
FRONT MOUNT INTERCOOLER
GREDDY BLOW OF VALVE
ALUMINUM RADIATOR
ELECTRIC FAN
 SS TURBO LINES
DRILLED AND SLOTTED ROTORS
 EIBACH SPRING
KYB SHOCKS AND STRUTS
WELED DIFF
ARK BOOST CONTROLLER
APEXI SAFC NEO tuned!
Z32 MAF
550CC INJECTORS
WALBRO FUEL PUMP
 AEM UEGO WIDEBAND
TURBO TIMER
3" INTAKE PIPE WITH FILTER
PIONEER RADIO WITH CD/AUX
NEW SPEAKERS (FORGOT THE BRAND)
 WHITE FACE GAUGE CLUSTER
KOUKI DOOR PANNELS
ACT 6 PUCK CLUTCH
jbracy7
Car: 94 GTS TYPE-M in a dozen pieces
It all depends,on how he maintened the car,if he rebuilt the sr first,really a crap shoot,be ready to repair lots of wiring, chaseing gremlins,and stock up on your headache meds of choice
blkvrtswp
Car: 93 240SX Convertible
SR20DET FP 20G Turbo
If the only tuning is an AFC, it isn't safe at all. If it has a tuned ECU and then fine tuning with AFC, that is good. I would insist on a compression test to verify the tuning (or lack of tuning) has not led to detonation.
panda240sr
blkvrtswp wrote:If the only tuning is an AFC, it isn't safe at all. If it has a tuned ECU and then fine tuning with AFC, that is good. I would insist on a compression test to verify the tuning (or lack of tuning) has not led to detonation.
This is what the seller responded. He owns a performance shop so I dont.
" You are not making any sence when u have bigger injectors the computer sends the same signal which means you are dumping more fuel the afc takes away fuel in percentage to allow it not to run too rich. It also modifies the maf signal so you can use a z32 maf. It does not control any timing the factory computer still do that"
He also said the car is running rich. Does that matter?
s14wayzz
Car: 1998 240sx
most reflashed ecu's are gonna run rich. It's not a bad thing..better then leaning out lol
panda240sr
So a few things, is this even a safe setup for dd ? Would I need yotune it because I heard apexi safc neo is caca. He says the car puffs when floored for a second. Blackish grey smoke and he said its because its a fat tune or some s***. Halp pleasee
