Please abuse the search button as this topic has been covered waaaaaay too many times already. Btw, an S15 turbo will not yield you 300whp. Close, but no cup of tea unless you mod the hell out of the engine and put the turbo past it's peak power bacnd which willultimately cause the turbo to **** itself.Cooch wrote:what do you mean like what am i getting into to get that much? i was figuring doing the s15 t28 or i can get a good deal on a t3/t4 what else will i be needing? - Brad
Depends on the turbo. It's a safe bet to get a better head gasket and ARP studs while you're at it when shooting for that kind of power. Don't put on a t3/t4 with stock injectors and raise the boost!Cooch wrote:so the ca has an 18 psi max? - Brad
What he said. People list target HP numbers all the time, but never seem to list target RPMs for that power. Torque numbers would be useful as well, but no one seems to think that way. Target PSI at a given RPM would also be more helpful than a HP number. For instance:Looneybomber wrote:I'm assuming you have already thought about your drivability?
Ah, ok. 450+ HP, with proper upgrades.Cooch wrote:i understand what you are sayign but i meant it was just like a one or two word answer like is this even reachable in that engine...and the 320 whp is just can it my daily driving will probally be around 200-250 range thats way to much for everyday- thanks - Brad
Short answer...yesCooch wrote:i understand what you are sayign but i meant it was just like a one or two word answer like is this even reachable in that engine...
thankyou, that was the info i was looking for when i posted thanks everyone - Bradr34 gtr wrote:yes, its very reachable. youll want some injectors, larger maf (or map sensor if possible), a metal head gasket, a t3/t04 turbo and a new manifold, a fmic, boost controller, intake, exhaust, some gauges, a turbo timer and some fuel management (sds, fcon, power fc, e-manage, etc.). youll be good to go.
oh! and dont forget the all important limited slip rear end and some wider wheels with some sticky rubber. 320whp in a 2700lb car will be like a rocket sled.
- tim
