The car only runs rich for a fraction of a second in between shifts and when you let off under accel and the BOV opens. Its not enough to foul your plugs. I've always changed my plugs with every oil change only because I use the NGK coppers.5 Skware wrote:Hey guys I was just interested in knowing how often you swap plugs in your motors when running a atmosphere vented BOV? From reading on here it seems that the missing air makes the motor run rich at times and I would assume that it would need plug changes more often than a motor with a recirculated BOV would. Also when running a atmosphere vented BOV do you notice any backfiring or flame shooting (not a bad thing). Thanks in advance
fouling out plugs ever 2 weeks but that wasn't because the BOV, I still have to tune my SAFC once my motor is back togther. For some reason my car was running very rich.5 Skware wrote:Thats what I had originally thought as well but after doing some reading on here it seemed like some people had problems with fouled plugs. Thanks for the info
Yeah, thats what I was getting at. A set of spark plugs is as much as a qt of Mobil1rico05 wrote:I mean, BCPR6ES-11s are only like $4.85 a set, so it is no biggie to change em.
I use 7´s on all upgraded CA´s without problems but maybe different gas here.rico05 wrote:7s are a bit cold for a standard or lightly boosted CA. I had a discussion with a local guru (11sec daily driven Startion) and he runs 7s with a TO4E. He said unless you are boosting 20psi+, 7s will foul quick. I have had bet luck with 6s at 10psi T25G.
