How "new" do plenum ring gaskets need to be? Can they be re-used?
JedCoop
Car: 94 Q45t w/TCS, 92 Q45 w/TCS, 91 Q45 touring (RIP)
When you pull the plenum on a G50 you generally replace the 8 ring gastets, right? Conservatively this is the safest bet.
But if I had replaced them a year ago, and I needed to pull the plenum again, do I really need to replace them, or can I just reuse them... I recollect they cost about $50 to replace.
What experiences have others had on re-using the plenum rings?
DAEDALUS
Car: 1990 Infiniti Q45
I thought they were about $3 each, but Joe's prices may have gone up considerably since the last time I bought them. We're getting Benzed perhaps.Depends on how soft they are. They need to seal, so they need to be compressible. Worst case, you get a vacuum leak and get to replace them then.
JedCoop
I just looked it up. $3.55 each... about $30 for 8. Better than I remembered.
The reason why it is more worthwhile to replace them is because a small vacuum leak can be hard to diagnose.
DominickJ30
Car: 1993 Infiniti J30t
JedCoop wrote:I just looked it up. $3.55 each... about $30 for 8. Better than I remembered.
Replace them. Do you really want to pull the plenum again for the vac leak?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Last time i checked the FSM it didnt state they needed to be replaced... So since theyre newish id leave em alone.
squeefoo
1994 Nissan Maxima SE
1999 Infiniti I30
2003 Nissan Maxima Titanium
2006 Nissan Xterra Off Road
2012 Infiniti G37x S
I've reused mine for about 5 years now having the plenum off about 5-6 times (Leaks and injectors). I almost hate to bring it up again but I put Permatex Hylomar on them, so I could reuse them, same thing with the AAC valve gasket and trans. gask.
I also aimed the crossover hose clamps at the openings in the upper plenum so they could be tightened occasionally with a socket and extension when the hose takes a set.
JedCoop
After reading Daedalus' reply I decided to change the #6 injector in my '92 this morning instead of wiating for gaskets to get shipped. When I looked at the installed gaskets they were still pliable and looked fine.
Car runs much better now than before. Popping the plenum just enough was no problem, I detached just enough so I could space the plenum up by two hockey puck thicknesses. Instead of detaching the hose to the IAC/AAC I just detached the IAC from the plenum, and detached a few other odds and ends. Turned out so much simpler than removing the whole plenum. Now I am just waiting to hear others chime in and tell me I should've changed the gaskets for sure.
Q451990
I think as long as they're flexible you're fine... and I'm a "do it while you're in there" kind of guy.
Glad to hear it's running better with that new injector!
Heath
