how mush boost can a stock KA take??
95s-14
Car: 95' 240sx/se
Anybody know about how much boost a stock DOHC KA can take without blowing anything up?? thanks
-RJ-
Car: S13 Convertible, 99 Frontier, 03 Sportage, 96 Protege
it depends on how well your motor is. A buddy of mine told me that 8 lbs would be fine
95s-14
Car: 95' 240sx/se
yeah it's in decent sape but i'm looking into gatting the crappy SS autochrome cheap turbo kit which is set internally at 8psi for my beater beginer hatch drift car but one guy told me 10psi and another sai 6 so idk 8 sounds pretty good nice in the middle thanks
DroptopDrifting
Car: 94 240sx limited edition se convertible
get a knock light, wideband, and safc.make sure your a/f ratio stays ok and slowly keep raising boost. if the knock light comes on, you know where your limit is. my friend has a 98 with 35k on the stock ka. hes boosting at like 16psi fine and someone i talk to with a 92 wont go above 8psi. whereas this chick i know has a 91, turboed a dohc with like 165k miles on it and is happily driving around daily at 12psi, got it up to 14psi at the track.
it's all in how well condition the motor is in and how the compression is, how often the oil was changed, etc.
Import_Ant
Go to the Ka24DET forum... there is an entire thread at the top stickied to answer this for you.
Florida240sx
Until it blows. Check the sticky at the top of kat forum
mattrcspeed
Car: 95 240sx
a stock ka can handel over 30 psi just get a diff head gasket use stock internals
WI_S14_Goldie
Car: 1995 Nissan 240sx SE, 91 240 fastback LE, 1997 kouki S14, DD = 93 Nissan Maxima
mattrcspeed wrote:a stock ka can handel over 30 psi just get a diff head gasket use stock internals
haha... >30PSI seem a "little" too extreme buddy...he's talking about reliable psi...and boosting that high on a stock block is just crazy.
Logan76
Car: Junk
The stock block would never handle 30psi without extreme amounts of methanol, an amazing tune, and then it would still probably only make it through one dyno run...Thats out of the usual Topmount T3 flanged turbo kit for a KA, the T25 is useless at 30lbs anyway, it turns into a hot air pump at anything above 18psi...
boznuttz
Car: MS13
Use that SSAC turbo kit and you'll be lucky to even get a few miles on your car before blowing the engine without a proper way to control your fuel. SSAC makes HORRIBLE turbos, and I have heard my share of horror stories.
You guys also have to realize that not every turbo is the same. 4 psi on the T3/T4OE 50 trim and a/r or .64 nets me close to 180 or so at the wheels while the SR T25 at 10 psi only gave me about 200 or so.
Guys...different turbos flow different amounts of air. That should be common sense. What your internals can handle is based on the power output, and not so much how much boost you can run......
10 psi on a T25 is going to be miniscule compared to 10 psi on a T66.
It's all about having a good tune. You can adjust the afr all you want, but unless you retard timing accordingly as you up the boost, you will predetonate and get one giant KA paperweight.
A safe goal is around 350 rwhp on a stock block with a good tune.
Logan76
Car: Junk
I agree, that you must have ignition timing control, piggybacks like SAFC's and DTEC and E-manage and all those other fuel controllers are great, but without a way to retard your timing you'll blow your poor lil' KA up.
electricman
Car: 98 240sx
just go 8-10 psi on a stock ka and decent afc tune and car will run great...had this setup on my car for 2 years no problem then went a different direction...sr20 that is...but good luck
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
Jason Rhoades rebuilt, yet stock block KA makes 500hp from a GT3071R which will probably be close to 22 PSI.
