nismojunkie »
https://forums.nicoclub.com/nismojunkie-u12812.html
Sun Jul 18, 2004 3:39 am
ya it is running. it si a 5 spd, with a brand new clutch and throughout bearing in the process of being installed. the motor has 2 new ( replaced within last 3/4000 miles) belts, starter, fuel filter, water pump, thermostat, , clutch slave cylinder, master brake cylinder, brake pads and recent oil change. the only probelms the motor has is it will stall sometimes when you start it cold, i dotn know why it does that.
