WDRacing »
https://forums.nicoclub.com/wdracing-u3125.html
Thu Oct 12, 2006 11:42 am
I ran 8 psi in mine for awhile, it would slip in 5th if I was racing. At 10 you're looking at alot of slippage. If you a good opinion on clutches, I'd use SPEC, flywheel too while your at it. I have a stage 4 and it feels like stock, cept maybe initial slip backing out of the garage. The rest is awsome, pedal is light and it will hold more torque then most of our cars will see.
Nissan did make a good clitch, they put them in the Skyline. Mine didn't slip unitl I started running 20 lbs of boost. It held a bar of boost for a year and I don't drive like a lady.
I'd say stop at 8 psi, or have a plan to swap the clutch within a fairly short time.
WD
