ken240sx »
https://forums.nicoclub.com/ken240sx-u27409.html
Tue Apr 25, 2006 8:07 am
depends on what you mod, if you dont mod anything internally then you shouldnt have a problem. If we're talking about valvetrain components like cams where you raise your rpm range then all you need to do is get rid of htat pesky rev limiter. many people with autos just start in 1 and bump it up tot he next gear right at redline. also if you're doing major mods to your car, your probably gonna want ecu tuning anyways or a jwt tuned ecu, which will allow you to adjust your shift points, hence no need to swap if you can tune your shift points higher.
