How much will it cost to fix this looking for prices
06m35rob
Car: 2006 m35 infiniti
Just wrecked my car out it in a pole tweaked the area that holds the sway bar bushings not sure if the frames tweaked, I think it might be. Motor still runs, suspension not sure. I need to know wat I'm looking at prices wise? And if it will ever drive the same after fram work??? Plz help
If the sway bar mounts are tweaked, it's got frame damage and will be a total loss.
A 2006 M35 is only worth $3-5k private party, so even minor body damage means it's a total loss from an insurance perspective.
You'll spend more than the car is worth to have it straightened on a frame jig.
06m35rob
It's not reported and I'm not going through insurance there talking about 1900 and that it will drive the same no police report hit a pole and took it home
There's your answer.
Larz
Car: 2019 Q70-L RWD
If your insurance quoted $1900, then your insurance company knows about this, even if they aren't getting the bill, right? If so, that quote was at insurance rates which are lower than normal shop pricing. Your cost will be significantly higher, but less than replacing with a similar model of the same year.
