madtown240 »
https://forums.nicoclub.com/madtown240-u25985.html
Tue Dec 27, 2005 10:15 pm
Make sure you get a motor set, which should come with motor, trans, FULL UNCUT WIRING HARNESS, starter, altenator,all engine senors, ignitor chip. and you will need a 5 speed trans harness(SR or KA) you'll want to see if you can get a factory side mount and piping to save money. At bare minimun do a clutch, fuel pump,some form of a intercooler, an exhust of some kind. Its going to be hard to do the swap cheap and still end up with a good result, but it can be done with good research and hard work. Good luck
