How much will a half an inch raise/drop mess up my alignment?
kenversusryu
The height on all four corners are all different height (due to eyeballing my coilover). After 4 tries.. i just gave up. Time to try again but my question is.... If i raise or lower a corner how much will that change my toe and camber? I plan to raise/lower at the most a half inch and at least a quarter inch so the difference in the front and back is a little less than a half inch. Is there some sort of formula? Thanks in advance.
Shouldn't make much difference. If anything, having it "even" will help.
Definitely recommend an alignment after the adjustment though.
BarnDog296
Car: '93 Nissan 240SX SE Fastback KA24DE DOHC
You can lower your car up to 1.5" and not have to worry about camber, but you will need to have your car re-aligned.
I just had mine done recently for Tein S-Tech springs which are 1.5" drop
lbrowne
Always get an alignment after messing with ride height.
You don't want to find out the hard way of replacing tires with uneven wear.
