How much volts is maf suppose to get??
Omni
i wanted to know cause when i checked my maf i was getting only 6v and im not sure if that is right thats why i wanted to ask u guys....when i have the maf plugged in the car starts for like a couple seconds then dies???could it be the timing issue or what???
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
The signal from the maf to the ECU should be 0-5V like all the other analog sensor signals. Are you talking about the power supply to the MAF or the signal voltage from the MAF? Either way, it looks to be wrong.
Omni
well i wasnt using a odometer i was using one of those testers with only 3 voltage reading on it which is 6v 12v 24v and continious and on the bottom it has the + and -
Booztd 3
Car: 1990 Nissan 300ZX TT
My suggestion - Get the right tool for the job before speculating.....
Any competent DIY'er should have at the minimum a voltmeter...
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
Digital Multi-meter ($20) at a minimum.
I use an old analogue VOM from time to time as well.
Omni
you guys are both right...so i will get my hands on one asap...not gonna deny the fact that ...that is a needed item...but thanx for the info guys
l0nestar
2004 Toyota Altezza
Check your AFM wiring. You should have two grounds, one +12v, and one 0-5v.
Omni
i have a series 2 sir....and series 2 only comes with 1 ground 1 positive 1 signal
l0nestar
2004 Toyota Altezza
Ah, no worries. I keep thinking N62 (Z32).
