How much transmission fluid does my RB take?
pumpiniron
Car: 1990 Nissan Sileighty SR20DET
Before I drop my RB20DET in my car I want to know how much transmission fluid the transmission takes? Also what is a good brand/weight to put in there?
Bronze MFP
Car: 1987 Nissan 300ZX w/digital dash radness
I think its 2.5 quarts*edit*yeah +1 for redline as well. best transmission fluid i've ever run.
Modified by Bronze MFP at 3:57 PM 7/14/2006
RB20DETodd
Car: 92 Nissan S13 coupe SE RB20DET
Bronze MFP wrote:I think its 2.5 quarts
, Redline Mt-90 is good, or 75w-90 gear oil i like the redline stuff though for the transmission and the diff!
pumpiniron
Thanks for the fast replies... I figured it would be easier to put transmission fluid in the transmission when it's out of the car as oppose to when it's in the car lol.
DrifterTom
Car: 90 rb20 coupe
hmmm this sounds lika a mess on the floor to me
RB20DETodd
pumpiniron wrote:Thanks for the fast replies... I figured it would be easier to put transmission fluid in the transmission when it's out of the car as oppose to when it's in the car lol.
haha yeah its all gonna leak out the back lol where the driveshaft goes in, its easy, pull out the shifter and pour in.
DrifterTom
Car: 90 rb20 coupe
now we be thinking all clear and stuff
pumpiniron
That's all you have to do once it's in the car? Pull out the shifter assembly and pour it in? Is that how it was designed to be filled from the factory? That's awesome!
pumpiniron
Well if it leaks out the back where the driveshaft is why wouldn't it leak out when you were driving up a hill or something? That's odd...
FriedEGs
Car: 1995 SE, Roast Beef!!
really?! you'd take off teh transmission with teh driveshaft still attached?! i'm willing to bet that something prevents it from leaking out.. like.. THE DRIVESHAFT AND THE SEAL!!! i dunno....
skillzilla
I usually fill from the side of the transmission until it starts leaking out, then cap it. Just over 2 quarts usually, which is correct per the spes Ive found online.
OKRB20DET
Car: 1990 S13 coupe
you go ahead and do that man...fill'er on up!
DrIft Ready
Car: 1990 silvia built sr..
same as a ka tranney
Kansei240sx
Car: S13 - RB25 Circuit car
71 240z - street/track day car
AE86 - Daily Drizzle/track day car
Z31t - Paper weight/street car
I agree, its not hard to fill it up when its in the car, get a 5 dollar pump and fill through the side hole... Nissan did put it there for a reason......
Shocker
Car: 89 240sxHB rb26/30
dont waste money on a pump.. just remove the shifter, get a funnel and pour it through there. good to go!... just dont get any on your interior...
DrifterTom
Car: 90 rb20 coupe
yeah that would be stinkier than a bangkok whore in mid july
OKRB20DET
Car: 1990 S13 coupe
Shocker wrote:dont waste money on a pump.. just remove the shifter, get a funnel and pour it through there. good to go!... just dont get any on your interior...
so its A.spend 5 bux on a pump or B.risk getting fluid inside your car....
or C. In my case have access to dealership stuff and fill it in 3.4 seconds
RB20DETodd
OKRB20DET wrote:so its A.spend 5 bux on a pump or B.risk getting fluid inside your car....
OKRB20DET
Car: 1990 S13 coupe
RB20DETodd wrote:
why thank you!
Kansei240sx
Lmfao!
