the mechanic said there was a chance to replace the head gasket.
he gave me a quote for the job might be around $1200.
does it really cost that much for this job?
anyone did this before can tell me much you paid ?
Thanks
ARKQX33V6 wrote:A head gasket or 2 can be expensive. Before doing it do a compression test first at least or a leak down test to verify 1 compression values at all cylinders and 2 verify the compression is being held.
Oil and coolant are non compatible, but will often show up with a cold engine going through the heat then cool down cycle.
Drain your oil into a clean pan and see if you have coolant in it, not just a drop or two. Drain your coolant and check for oil before doing head gaskets.
You must be careful and clean. Do not cross contaminate.
And to answer your question the costs can go high depending on:
head(s) condition
cross contamination and damages to cylinder wall, valves, oil pump
twisting of heads, broken bolts
$1200 is minimum, but if a head gasket is not needed $1200 can be high for a slight clean up that you can and should do your self.
Cost to verify compression, oil and coolant about 5 hours of your time and a few tools.
