How much to replace every electrical wire for KA24DE?
VinceSez
Car: 1992 Nissan 240sx
How much would it costs to replace the electrical wiring for the KA24DE? I've searched the forums, but found no info. Also, how much would you think labor would cost?
Red coupe
Car: 92 Nissan 240sx Coupe
Id imagine labor costs would be insane....but the cost of the wires would be alot too...youd be supprised how many wires are in a car. I would take it that you found nothing on this because no one would ever do it.
ILikeMy240sx
Car: SR Power
just the main wiring harness for the engine? Shouldnt take that long... Just get a different harness, unplug all your wiring connectors, pull it out, snake the new one in. Not that hard at all.
chrislis
Car: 1998 240sx sE!
yeah i would only assume they would come as full harnesses to plug and play pretty much. if not you're in for an asswhoopin because just the wires to the ECU alone are rediculous.
Red coupe
Doh! im gonna go practice reading...I though he was talking about the whole car for some reason...yeah engine bay seems more doable....
VinceSez
lol, yea i was talking about the wiring for the engine itself. i might check out the junkyard or check out how much a complete harness would cost at the dealership =X
so if i were to buy a complete harness for the engine, it would replace every connection, including the wiring to the coolant temp sensor?
ILikeMy240sx
Car: SR Power
chrislis wrote:yeah i would only assume they would come as full harnesses to plug and play pretty much. if not you're in for an asswhoopin because just the wires to the ECU alone are rediculous.
yup... the plugs from the inside of your car are a huge biotch to get out and if you have ABS..... thats even worse because the module for ABS sits right in front of the hole for the wiring.
Anways, have a friend to help you out snake that plug out and snake that plug in.
574-240sx
Car: Nissans, Toyotas, Subaru
full KA24DE harness shouldn't run more than 120shipped. I have sold complete harnesses for $75.
VinceSez
cool, thanks for all the help!
VinceSez
one more thing.... so if i buy a new complete harness it would replace all the wiring to the sensors?
Kenrik
Car: Nissan 240SX Coupe
Infiniti G35 Coupe
Nissan Versa Hatch
VinceSez wrote:one more thing.... so if i buy a new complete harness it would replace all the wiring to the sensors?
yes but if the reason you're asking is one of your conectors is messed up then just go to a junkyard and cut that sensor wire off a harness then splice it into your harness... simple..
VinceSez
kk thanks again my nico brethrens!!
