DCaff300ZX »
https://forums.nicoclub.com/dcaff300zx-u136230.html
Sun Aug 16, 2015 2:10 pm
Well, $4,500 is a little steep for a simple paint job, but not for a high quality job and especially if there is any rust removal or dents or other body repairs needed. $2,500 should be for a decent job without a lot of body work or prep, and from a nationwide chain type shop (less quality) and up to $5K for a high end shop that uses quality paints and techniques.
When it comes to paints, Plastidip and a correct automotive finish are not even in the same universes for both quality and looks, and I can't imagine any body shop even considering using Plastidip paint- which is applied from a spray can, and intended for other uses due to it's nature of being easily removable.
Automotive finishes require repair bodywork and preparation before applying primer, paint, and clear coat which are intended to last a long time with a very good luster and durability, while Plastidip was created for quickie painting of small items where the owner will want to remove the paint easily, wants to change colors often, and doesn't care much about the look quality or it lasting very long.
Hope this clears up your situation!
