C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Thu Apr 22, 2004 4:46 pm
I ran stock timing when I used an FMU. With the E-Manage, I backed off about 3 degrees at the highest airflow voltages and gradually decreased retard at lower airflow and RPM's. The only reason I think I needed to do this is becuase the ECU is now being fooled by the E-Manage. The ECU thinks it is getting less air than it actually is so it thinks the motor is under less overall load so it runs more timing advance. I had some light detonation otherwise. I'm only running 6.5 psi, so you may need a couple degrees retard more than I do.
