How MUCH
SEBZX79
Ok i am going to buy some oil over the next few days to flush everything out of the Q. What I need to know is
How many quarts does the trans take?How many quarts does the engine take?How many quarts does the differential take?
I saw somwhere that the trans takes 14????
Diff - Buy 2 bottles.Trans takes 15, but you won't get 15 out just draining it.Oil - 6 quarts.
http://www.q45.org/techinfo.html(Credit to "Vududoc" for most of the info.)
DAEDALUS
Car: 1990 Infiniti Q45
Diff is 2 3/4 pints API GL-5 80W90. transmission capacity is 11 1/8 qts, but you need extra to get a good percentage of the old stuff replaced.
Jesda, please double-check the specs on your site.
I got them from a post made here in Infiniti Online Mechanic. I'll make corrections.
Q45tech
The confusion is a BG ATF Flush machine uses 14 quarts to fill to make sure all [most] of the 11 quarts capacity is exchanged.
SEBZX79
Thanks guys this helps alot.
