How much?
leesredgt
Car: 1992 Toyota MR2 N/A
1991 Toyota MR2 Turbo
ok i just got my rb25 swap running and installed a apexi avc-r boost controller.So now every time i get in the car its begging me to turn up the boost so before i go and blow it up (and i know this has proably be covered berfore i just cant find it) how much boost can the stock BOV handle and what is a safe boost level that i can run with the stock turbo with out frying it untill i get enough money to buy me a bigger turbo
ryan15
Car: 1990 240sx
Your BOV will probably handle 18-21 lbs, and the turbo I wouldnt go over 12psi MAX, or the turbine wheel will probably explode.
leesredgt
does anyone else have a second opinon?
digzsublime
Car: 95 S14 w/ LS1.
Ryan speaks the truth. 12psi is a safe max for the stock turbo. Yes, there are some people running boost higher than that.
As far as I know, the stock turbo is past it's peak efficiency at anything past 14 psi.
Yes this has been covered many times. But, the reason most people would say not to exceed 12/13 psi on the stock turbo is because of the ceramic blades in the stock turbo. When run at 14psi or higher for prolonged periods, the factory turbos tend to die quickly.
Plus, 12psi on your stock setup will still be plenty quick. Although, I don't know if I'd even go that high without some kind of tuning. Just an opinion.
Joe
leesredgt wrote:does anyone else have a second opinon?
none needed.
12psi. any more and you are just heating air. not making power.
leesredgt
so i shoudlnt have to tune it yet right untill i upgrade right?
skylinegrl13
Car: 1995 Nissan 240sx RB26DETT swap
you should tune if you are running bigger injectors, AFM's, tons of boost, aftermarket computer, etc...but of course in the end it's your choice. i like to think of it as an extra insurance policy, you know exactly what is going on under your hood when you run your car, and it can prevent some costly damage down the road.
and count me in for the 12psi max for stock turbo opinion. especially with factory turbos, more boost does not always mean more power. after a certain point it just means more detonation.
