Unnatural1 »
https://forums.nicoclub.com/unnatural1-u59065.html
Sun Nov 16, 2008 2:24 pm
If the 02 Q45 uses the same MacPherson style front suspension as the older Q's then you don't have any need for a spring compressor. You simply need a jack, basic hand tools (sockets, ratchet, wrenchs), ball joint fork (or a press), and a big hammer. A small sledge hammer will do the trick and a dead blow hammer would be nice too. Download the FSM as it should give you a basic overview of the process.
As far as spring pressure goes, yes the spring is under tension while the car sits on the ground. But, once the wheel is raised off the ground the spring will extend as far as it is allow to by the strut. The only time you really need a spring compressor is when replacing the struts or the springs themselves.
This is a relatively straightforward job. In general, with a suspension setup like this you will remove the nut fastening the ball joint shaft to the steering knuckle. This shaft is pressed into the knuckle when that nut is tightened so this is where the hammers will be needed. A ball joint fork is a cheap tool that can be used in this case as you will not be reusing these ball joints (do not use this tool for removing ball joints you will reuse). It is basically a wedge you insert between the knuckle and the ball joint. Then you hammer it in until it forces the two pieces apart. Or if you have a hammer and a long prybar (around 3-4 feet long), you can pry the joint and the knuckle apart while the bottom of the knuckle is struck with the hammer. That is usually the most trying part of this procedure as reassembly is much easier. Then remove the control arm mounting bolts and anything else bolted to it (sometimes a sway bar end link, tension rod, etc.). After that remove the control arm and ball joint as an assembly. When you reassemble this part you will want to tighten everything EXCEPT the control arm mounting bolts. Tighten these bolts when you lower the vehicle. This is to prevent binding the control arm bushings when the vehicle is lowered and the arm is in it's normal position. It may be easier to do that part on a pair of ramps.
Also, unless there are adjustment cams on the lower strut mounting bolts or the lower control arm mounting bolts there is little need for an alignment in general. HOWEVER, with your tires wearing as they are, the alignment should definitely be reset. A 4 wheel alignment should always be done when there are rear adjustments as the rear adjustments affect the front.
Hope that helps you make your decision. I know the feeling of being laid off. It's a bad place to be but the good news is it's an opportunity to make a new beginning. You will come out of the other side of this stronger!
