late 260 z (sept/74)
California car with blue plates located in Los Angeles
L28 n54 block p90 head
4speed
dual SU round top carbs
* = work done at mikes z shop in whittier CA
*energy suspenion poly bushings (master kit)
*kyb shocks
*eibach pro springs
*rebuilt steering rack
*new tie rod ends
*new ball joints (from germany w/ zirk fittings)
*new brake pads + shoes
silver konig rewind 15 x 7 on new 205/50 (less than 7miles)
brake master cylinder
msa one piece drive shaft
new clutch slave
oem harmonic balancer (crank pulley)
60 amp alt ir
weather stripping/window seals
240z lower valance
good chrome front bumper
msa head light covers
msa bre replica fiber glass lower dam
msa bre replica rear spoiler
personal steering wheel
interior pretty decent shape except dash
new center console
new speakers installed by previous owner but no head unit
new door lock cylinders and key
no dents (previous owner had a msa bodykit type 2 molded in, i took it off and primered the unpainted areas)
CONS:
running lights + dash lights recently went out mysteriously (headlight stop lights and turn signals still work) dont have time to look through junkyards for another light switch stalk
need to rev to 3k rpm to turn on alt. (wiring was messed with from previous owner, clutch and seatbelt interolock is bypassed)
no ac belt but compressor is there. not sure if its functional
heater core is clogged
hvac blower fan recently went out withdash lights
needs front turn signal buckets. early or late will work. harness wires is extended if you choose to run early. never got around to finding a set.
EXTRAS:
original 74 260z FSM book
lots of extra badges in a box (280z, 260z, and datsun badge)
door panel clips etc
some new weather seals still in bag from previous owner (didnt have time to figure out which went where)
set of 5 spoke american racing rims (14 x 6.5?)
