Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Wed Sep 10, 2003 2:55 pm
Brain power works well in diagnosis, only if you have test equipment not normally found at dealers. Sun ignition analyser or similar to view the waveform of the spark after the coil. Possible to glean information by looking at each coil input with an oscilloscope........looking for differences.OBD2 does it for you.
Other than a power balance, injectors can be mesured for flow on a special bench, the pintle lift point can be seen with a current probe and oscilloscope.
The problem is even master techs are so spoiled with the Consult that they may not have thought about or don't have the equipment or the time to develop non Infiniti proceedures.
Why waste money on a more expensive non standard plug, the oem NGK work well and that has been proven in 100,000 Q.
The reason you change plugs every 4 YEARS or 60k is to see the plug, make sure it doesn't/hasn't galled in the heat, and to evaluate any valve cover leaks that may need resealing.
The is no measureable differences in power for various plugs [that are satisfactory].Be a test case for us and after you report success in 4 years members might consider a more expensive plug.............we"ll leave the light on for you"
