how much quart do i put in for the trans
Emperor_Tha
how much do i put in since im fillin it up from the shifter. im using redline mt90.
Sil80315
Car: 1991 Nissan 240sx
2 and 1/2 bottles
drkidd22
Car: 2007 Toyota Camry SE...1989 240sx SE...2010 Altima Coupe 3.5SR MT
My SR20 took a gallon and can still put more in it. Should I drain it then if it's 2 1/2 Quarts?
slow s13
Car: cars, photo, music
drkidd yeah you should drain it just park it so its level and take out the fill bolt on the drivers side of the trany and any extra will come out
drkidd22
slow s13 wrote:drkidd yeah you should drain it just park it so its level and take out the fill bolt on the drivers side of the trany and any extra will come out
Thanks for the info, will do that asap
Emperor_Tha
ok thanks
C - ROD
Car: SR20DET pignose hatch
or u could let it spray out of the overflow tube which would make a huge mess & have ur whole car smelling like gearlube, just take out the fill bolt on a level serface
