How much pull or roll?
nieko
Car: 1989 Nissan 240sx
How much of a pull or roll would i need to run 15x7 +0 if i ran like 1.5 degrees of camber? because right now i have stock RUCAs and wow, the littlest i could get my camber right now with how low my car is is 3.8 degrees which is RIDICULOUS but its extremely flush right now, i used a bad and rolled the little lip in but im going to be getting spl rucas and going to take most of the camber out, aiming for about 1.5 degrees camber and im wondering how much my wheel would end up sticking out past the fenders. get it? ahah thanks in advance
nieko
oh also, im running 205/55 wondering if there was a better tire size or if thats pretty much the best size to run? thanks
onosqv
Car: '92 240sx Vert
Don't know what your idea of stock is... but when I had 16x8 +6 (effectively 16x7 -7 on the outside) w/ 225/50R16 tires, I was able to run "flush" w/ just a roll. Total camber was -2.
w/ a 15x7+0, you should only need to roll your fenders & it should tuck right in. Pulling doesn't make sense for the size/offsets you have. w/ -3.8 camber, it should actually be tucked, according to general consensus.
Maybe if you took a picture from different angles ppl will understand what your definition of flush is.
And if you searched through a few of the threads, you are running a pretty common size relatively, and no one else really has problems w/ this size rim.
nieko
ya i would say its actually tucked sorry didnt mean flush. well hold on lemme get some picks up.
onosqv
Car: '92 240sx Vert
Well, in that case, you shouldn't have a problem w/ 1.5 camber & ur current setup w/ just a roll.
Should be zero pulling required.
nieko
ok, thanks for the help
adrianfromthecastle
Car: 1992 Nissan 240sx
dude, are you taking care of my beloved meshies? I miss them
oh, and if your low enough, just bust out a roll of news paper and do a newspaper roll if you need to. But like QV said, you should be good with just a roll.
nieko
of course im taking care of them! got new tires of course haha and they look good, ill post a pic later i didnt realized how bent up they were though x) but they still hold air nice and ride good. thanks again adrian
nieko
