:: orion :: »
https://forums.nicoclub.com/orion-u7549.html
Thu Jun 02, 2005 3:39 pm
Sounds like you bought some T3/T4 variant?
If that's the case, the TRIM is important...but...
I would bet that if it's a 50-rim or 57-trim...even a 60-trim...then ~12psi should get you to ~300rwhp or a little less, and 15-16 will most likely let you hit ~350.
The limiting factor on YOUR turbo is the .48 A/R exhaust housing...good for spool, bad for big #s IMO.
I'll bet it takes you an extra 1psi to reach those numbers I listed...the smallish exhaust housing will choke the motor a little.
- Brian
