How much psi should i run on my twin turbo
x300zxturbox
Car: 300zx
i have upgraded turbos and i was wondering how much boost i can run i have it at 14 and i was thinking maybe 18 and keeping it safe? i want a significant upgrade from what i have.
freakonaleash1187
Car: '93 300ZX N/A, '97 200SX SE
Do you have upgraded fuel injectors? If you have stock injectors, I wouldn't go above 14psi just to be safe. And I wouldn't go above 16psi on 91-93 octane gas.
x300zxturbox
Car: 300zx
Good call do you know if you can do a 2jz swap into the 300?
freakonaleash1187
*Tries my hardest to be nice and polite*
Bottom line, not worth it.
x300zxturbox
Car: 300zx
Haha yeah i was just debating i figure i could just sleeve the engine block and run some crazy boost on big turbos and just have a monster 300zxwe need to bring the 300zx back
freakonaleash1187
You don't have to "sleeve the block", you just have to upgrade the internals if you go past 500-550hp, thats when the stock internals will not be able to take it. And keep in mind that you are limited on space for turbo size. And also, its not all about power.
NSR_s30
Car: '99 Ford F250 7.3L Diesel
'71 Datsun 240Z
x300zxturbox wrote:Good call do you know if you can do a 2jz swap into the 300?
Why?
WDRacing
Hell yeah you can swap a 2JZ motor in man. The 2JZ is one of the best motors made...period. I think that would be madd tight dude. Get a set of T88's and dual 5" downpipes...you'll be making crazy power. No VG30 is gonna come close to the 2JZ man...they might act like it...but they can't.
WD
Repo Man
Car: 2020 Frontier Pro4X
2003 Honda Accord
WDRacing wrote:Hell yeah you can swap a 2JZ motor in man. The 2JZ is one of the best motors made...period. I think that would be madd tight dude. Get a set of T88's and dual 5" downpipes...you'll be making crazy power. No VG30 is gonna come close to the 2JZ man...they might act like it...but they can't.
WD
dickie
Car: Killer Turtle
so wuts up man u get ur turbos replaecd since da 6th wen u posted u had stock 1s and blew up 1 of dem or wat?
WDRacing
x300zxturbox wrote:i have upgraded turbos and i was wondering how much boost i can run i have it at 14 and i was thinking maybe 18 and keeping it safe? i want a significant upgrade from what i have.
How much boost you can run is very relative to the specs of the turbo's themselves not just the internals of the motor. The VG30DETT is a stout pig of a motor and easily eats 500WHP on stock internals. But the stock turbo's are far from being able to reach that. The exhaust housing need to be big enough to flow a large amount of exhaust pressure, the compressor has to be big enough to provide enough volume for the motor to eat. And all of this has to be done within the turbo's efficiency island. But thats another topic entirely.
It's not all about the air fuel mixture. Everything needs to be takin into account.
WD
