White Comet wrote:nope not at all. u wanna make more hp than stock w/ less boost? good luck
From where?Thoughtful_One wrote:I will be putting a down-payment on an S14 SR20DET this coming Monday.
i find that hard to believeThoughtful_One wrote:Chicos240 or something like that made just about 200 WHP at 7 PSI with just an intake and catback.
I will have that and a turbo elbow, testpipe, flywheel, and downpipe.
the s14 sr makes more power partly because their stock boost is higher than s13 sr. this is why i cant imagine u'll get more hp then factory by turning down teh boostsrdub-t wrote: Its very possible to do 210 whp on 7 lbs. Import tuner did a article on an s13 with a REDTOP (t25) with just an intake and catback exhaust he got 187 whp! With testpipe and downpipe and fan deleat he should deffinatly be able to hit those numbers. Not to mention Hes an s14 which makes more power anyways! I say 210 whp easy
Where does it say stock boost is 10 PSI?White Comet wrote:stock boost is 10 psi iirc. true the vvt and dif turbo help over s13 sr. but when u take a stock s14 sr which has vvt and t28, turning down the boost wont get u more power even w/ some boltons
It says it twice, once when he posted it, and once when you quoted it.Thoughtful_One wrote:Where does it say stock boost is 10 PSI?
Hungryjoseph dynoed his car with almost exactly what i will have and he made consistent 230 WHP runs at 11 PSI.
I should be at the 200-205 WHP range at 7 PSI.
I just went through the thread and it didn't say it ran 10 STOCK. It just said the run was done at 11 PSI.0wn3r wrote:
It's 10psi...I just asked 240sxmotoring last Saturday. You're in T25 world thinking you want to be at 7psi. If you want 7, just go buy an S13 SR.
Why don't you just ask Hungryjoseph then, assuming he's got an S14 SR20?
This thread kind of sucks...
Why'd you pick up a flywheel before an FMIC? What kind of clutch are you running? What kind of "air filter"?
and again, WHERE ARE YOU GETTING THE MOTOR FROM? MAKE SURE IT'S LOCAL.
I'm guessing you'll be at 210-220. Just go get the damn thing and come back in a year when it's finally dyno'd.
Thanks for the comment... What purpose does it serve?redtop91 wrote:OMFG So much misinformation in this thread.
redtop91 wrote:S13 SR's run 10 PSI if you remove the stock line to the solenoid that has a restrictor in it.
changing vacuum lines dont make your boost go up you also have to remove the solenoid that has a restrictor in it You said it your self and stock is what came out of the factory with out having to remove things to make more power. at least im not acting like a child by calling you names. don't get mad just because your wrong its ok every one makes mistakes every now and then even me.redtop91 wrote:Wow. You are dumb. If you consider swapping vacuum lines a modification, I feel sorry for your SR. Anyways, I'm not going to continue to quibble over little things feel free to stop whining.
now im wrong? i didn't even change my answer how can that be? anyways changing oil filters its not a modification its maintains like changing your oil on less you get an oil reallocator kit now that will be a modification. like i said its ok to make mistakes i do em all the time.redtop91 wrote:LOL. You are wrong now. Man it must be a difficult modification changing your oil filter from an OEM nissan to an aftermarket K&N but in your case I'd recommend Fram .
