How much power?
lilskyline240
Car: 90 240sx w/ rb30det
I am Goin to be install a Rb25det into my 89 coupe.....i was just wonderin how much boost can i run on the stock turbo safely....and how much HP would that possibly put me to?? i will have a 3in piping from the turbo back, a FMIC and a Walbro 255 Fuel pump.....
~BEN
dekand
Car: 1995 240sx SE
you could have searched for this answer but 12psi max on the stock turbo 10 to be really safe... that should be around 230-260rwhp depending on the motor but you wouldn't know until you dynoed it ... and then you could get more tuned out of it probably
Sky240PWR
Car: 1991 Nissan 240SX
well I have have a 97 RB25DET and it's pretty much stock besides, intercooler,intake manifold,full exhaust, air intake and I'm at stock psi and I dynoed it at 250 whp
themadscientist
.9 bar.
Nameless EJ6
Car: What the **** do you think.
Questions like this are annoying. There is no answer for 'what horsepower' or 'what can my turbo handle'.. every piece on every engine has a different lifespan and different capabilities due to the fact that it's not possible to perfectly engineer everything to be the same... and yadda yadda.. we all know the rest.
Get on the dyno to answer your horsepower question.
Turn up the boost untill you blow the turbo into bits for your turbo question.
Stock turbo's are dumb.. if you want to start turning up the boost, save some money for a turbo that has been proven to handle the boost levels you desire. And generally, 1-3 psi above stock is safe for pretty much any stock turbo.
lilskyline240
the only reason i asked what boost level, is cuz i was gettin conflicting reports....i read on one site that it can handle up to 18 lbs on the stock turbo...then another said stock boost is all it can take....
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Ok check this out. MY friends RB25 dynoed at 275hp at 9psi, We took it back to the dyno turned the boost up to 12psi and it still made 275 peak HP. But before the peak it made a little more HP and TQ. Something happened around 5,500 and it just wouldn't make anymore power over the 275.
themadscientist
lilskyline240 wrote:the only reason i asked what boost level, is cuz i was gettin conflicting reports....i read on one site that it can handle up to 18 lbs on the stock turbo...then another said stock boost is all it can take....
.9, any more and it won't last long.
Kansei240sx
Car: S13 - RB25 Circuit car
71 240z - street/track day car
AE86 - Daily Drizzle/track day car
Z31t - Paper weight/street car
Since your RB25DET is a series two motor it doesnt have the ceramic wheel in it and is a ball bearing GT28. At least thats the turbo on my motor and can handle 18psi max which is stretching the limits of the turbine to max capacity, i would only run it at about 15 for power.
lilskyline240
Kansei240sx wrote:Since your RB25DET is a series two motor it doesnt have the ceramic wheel in it and is a ball bearing GT28. At least thats the turbo on my motor and can handle 18psi max which is stretching the limits of the turbine to max capacity, i would only run it at about 15 for power.
was that in reference to me?? cuz idk if my motor is a series 2 motor....i didnt get it yet....what yr was the series 2?
