injector size tells you nothing except how large the injectors are.it does not mean than an engine makes X hp. It just means the injectors can support X HP.Kittychubbs wrote:well around there most of the time the Injector size gives it away 740cc Nismo ones humm wealthy man!!^o^
its all about how well he tunes it and how well it is maintained. well tuned @ 400+ the bottom end will be fine.FattyMcBaggins wrote:I personally would be worried about how long the stock bottom end will last pushing that much power. I know the stock bottom end can hold 400whp, but for how long?
Nismo_Freak wrote:You need engine management for one which adds a few parts here and there based on which one you go with.
The car will live on the dyno to get an acceptable powerband out of the 272's matched with a 60 trim. At least you got the cam gears which will help keep some low end.
Get an electronic boost controller, the last thing you want is a manual ball valve sticking and blowing your engine.
overrated maybe, but they are cheap, and do serve a level of protection.Nismo_Freak wrote:Aeromotive FPR setup, and a set of valve springs would be beneficial.
RAS's are a bit overrated IMO.
I have no idea what you just said.Kittychubbs wrote:hehe crazy kid dont get mad XD the 740cc its a nice big size injector which throws lots of gas compared to the stock ones If i had a 390whp i wouldnt run 300s 400s cc injectors since it be to lean so the 390whp wouldnt go nowhere since gas its not there u cant make 420whp with 440cc injectors so Commonly used injectors for 420whp its around the high numbers over 400s cc so like 700s sounds bout right!! ectect so i said:Ahhh ha! he most likely will get this whp because of the size the injector is and that much fuel is goin to deliver (its right about there). doesnt sound is gunna be too rich or too lean, so that was a good guess try it its an 80% sure u will get it right!! hehe be open minded and youll learn lots kid!
it be like saying T25 ,stock injectors: 700whp! pfft!! not really get a bigger turbo/enginework/fuel delivery system and it will !!
and bout em T04E i got it all running for less than 1600$ thats including turbo kit and its accesories which i bought from a friend who sold his 240 and since i have an SR20DET on my other 240sx than why not try sumting different that came out cheaper. JIgga wut!
Valve springs you can buy at Enjuku, along with most other things.goodstuff86 wrote:hmm i have rocker arm stoppers where can i get ahold of the rest of the stuff?? Also which boost controller do you recomend ive been looking at a fewP.S. which engine managment would be most beneficial ive been looking at the new greddy and the AEM EMS wut do you think?
please do not hit the crack pipe before you post.Kittychubbs wrote:hehe crazy kid dont get mad XD the 740cc its a nice big size injector which throws lots of gas compared to the stock ones If i had a 390whp i wouldnt run 300s 400s cc injectors since it be to lean so the 390whp wouldnt go nowhere since gas its not there u cant make 420whp with 440cc injectors so Commonly used injectors for 420whp its around the high numbers over 400s cc so like 700s sounds bout right!! ectect so i said:Ahhh ha! he most likely will get this whp because of the size the injector is and that much fuel is goin to deliver (its right about there). doesnt sound is gunna be too rich or too lean, so that was a good guess try it its an 80% sure u will get it right!! hehe be open minded and youll learn lots kid!
http://www.takamotorsports.com/or have some made.goodstuff86 wrote:ok ill try that spl parts thing thanks also the guy who had the car before me put an aftermarket turbo on it he said it seized due to turbo lines and that i should replace them where would i find these?
no idea. i will let you know when my ecu gets here. however, after i spend some dyno time i fully expect to hit 400.nonvtecaccord wrote:karmakaze, how much power does your setup make, its real close to mine. just curious.
Carne guisada con mas salsa del habanero por favorKittychubbs wrote:hehe no english? than Nismo: ill take 2 carne asada tacos with a soda no caliente salsa por avorgracias.
You suck... so bad...Kittychubbs wrote:hehe no english? than Nismo: ill take 2 carne asada tacos with a soda no caliente salsa por avorgracias.
pongo mecarna in laboco, punta.Kittychubbs wrote:Hehehe poor kid, l. Keep it real. We all love Nissan!
