Postby
HxC_Nismo »
https://forums.nicoclub.com/hxc-nismo-u47634.htmlSun Aug 03, 2008 4:12 pm
usually cast manifolds hold heat in alot better and usually can hold whatever you can throw at em, if you want better flow just port em, but its not nesssary to upgrade unless you want to run a bigger turbo. i still run my stock cast manifolds with my hks gt2530's. so you should be fine unless you want to upgrade to a bigger turbo
Postby
KC240RB »
https://forums.nicoclub.com/kc240rb-u101156.htmlMon Aug 04, 2008 2:37 pm
Thanks guys. Just curious on my possibilities. I searched before I posted the question and resulted nothing. So pardon my ignorance. I see they can handle some good power.
Postby
Yellow4g63 »
https://forums.nicoclub.com/yellow4g63-u4416.htmlMon Aug 04, 2008 2:56 pm
It like a log manifold, it will work and get the job done just not the best for flow. You will save money tho just don't forget to put the external gate on that puppy.
