How much power can STOCK crank handle
KrazyS0b
Car: 89 s13 redtop, f*** Fidanza, Spec stage 2 clutch, Greddy FMIC, HKS SMF Reloaded, HKS SSQV
I just have a quick question as the title says how much HP can the STOCK crank handle? The reason I'm asking is because i am rebuilding my engine but i want a forged crank but i can not even find a Stock forged. All i can find are the stroker kits. I don't want to do that. Also anytime i find a crank not in a kit its $3,000 is that the normal going price? Im doing a performance build not an OEM build here is the parts list:
ACT Flywheel Cower Connecting Rods ACL Main Bearings ACL Rod Bearings Tomei Forged Piston 86.5mmISIS Oil Pan Kit
Thank you for any help.
lifewater
Car: 1990 S13, 1996 S14
What kind of power figures are you looking for? I cant see you needing a forged crank until 600-700+ hp... if that. The crank is not a weak point for the SR.
KrazyS0b
yea i was lookin at mid to high range 400-600 anywhere in there. Of course depends on turbo i get and everything. i was thinking about getting GT3582.
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
Mazworx runs a polished and balanced stock crank in his 1000whp S14. You dont need a forged one.
DETonatros
Car: 92, 240sx SR20DET
a friend of mine was some what in the same situation as you he didnt want to stroke his S2k so what he ended up doing is sourcing a stock crank and 'cryo freezing the crank" i cant remember the name of the company that does it but you should look in to it its not expensive i think they only charged my buddy like 275 for the dip
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
I've seen over 600 on a stock crank so I don't think you need to worry about it. 400-600 is a HUGE range of power, and requires vastly different parts as well as budget to get you there. What are you actually planning to do with the car?
V8slayr
Car: 97 240sx
On the Mazworx site they say the stock crank has been proven to 1400 hp. There is absolutely no need in considering replacing it unless it is damaged or something.
Seishuku
Car: 1987 Nissan S12, 5-speed, SR20DE+T 50trim T3@15PSI, Megasquirt 1 029y4
Isn't the stock crank already forged?
the converted
Car: '99 BMW M3 6.0
'20 Toyota Tacoma
Uh Huh Pretty much all of them are these days. Only reason to get a different one is to change stroke or radical lightening.
