How much power can it handle?
All things Altima Coupe.
khisanthax
I've been installing a lot in my 09 altima ... two head rests, two dvd/gps, carputer, av switcher, tv tuner and rearview camera.
I just blew a 15amp fuse which was connected from the front power socket but it had a three way socket connected to it as well as all the above mentioned stuff.
Does anyone know how I can calculate how much power I can draw from one cable/power source? Does the gauge of the wire matter on how much power can be drawn?
I just want to avoid blowing another fuse and I don't think that making the fuse bigger will solve the problem, am i right?
To prevent it blowing again, is there a way I can control how many amps flow through the cable?
Keyan
Car: 2013 Altima 4D 3.5 SL
You can draw as much as the fuse will allow Yes the gauge matters, if you pull too much power through too thin of a wire, it will overheat and possibly catch fire, which would be unfortunate. I would never put in a larger fuse on the stock wiring. I think others in here with more expertise than I can help you on what can be done to get more power to things.
