How much power can I produce from a L20b
General discussion forum about all things Datsun! NOTE: If your thread is specific to a certain model, please make sure you post it in the proper forum.
Rattler69
Car: 1976 Datsun 620 reg cab shortbed
How much power can a l20b motor produce and with what mods.... And what's a reliable amount of power in one???
PEZi
reliably... you could do some good headwork (port and poslish, shave.... etc etc.) and then go with some aftermarket pistons and run about 10:1 compression... and then aftermarket carb(s) and.... i dunno about 200 HP?
Rattler69
thank you , im just new to the datsun truck and engines and was just looking for a rough estimate to see if i should rebuild this motor and tune it up or just drop another motor in like a 6 cyclinder or drop in a chevy v8
PEZi
it'll take some work... but with the size of the truck that amount of power is plenty.... especially with the gearing
Rattler69
pplenty of power you mean the l20b or a v8 ? with a v8 im gonna have to change the running gear and put i decent rearend in the thing along with boxing and beefing up the frame. i kinda wanna stick with the l20b thou and pump that up
kamakazi620
Car: 620 datto
L20b (modded) is what he's talkin' bout,a v8 is a little out of hand in a 620,plus all the mods that go with it (choppin' up firewall body etc.)if ya want a v8 gets yer self a muscle car,for sixers vg30 is cool,but still lot o mods ta make it fit blah blah
stick with a L series or maybe a z22 hybrid
Rattler69
oh ok gotcha, ive just seen the v8s done and there pretty sweet i wanna do a sleeper type truck for street slash strip so it looks cool and ordinary but when i open the throttle i wanna hang with muscle cars like a 12-13 second run in a qtr
kamakazi620
Car: 620 datto
also look up info on a 4.3 chev v6 their cheep and plentiful and built right will make a reliable 300hp plus you don't have to chop up yer firewall,mate it to a firebird/camero 5 or 6 speed and maybe shorten down a astro van posi 10 bolt(some years of astro vans were 6 lug)and you should run a 13 qrt with cement in the bed! and BTW the reason i suggest this motor is edelcrap makes a 4 barrel intake for this motor (no EFI crap to screw with like the vg)
Rattler69
Thanks for the input and idea just wondering without the efi and motor swap if I'll be able to smog in CA
seang
Car: Ford Fiesta ST
According to chapter 14 in my JTR S10 V8 conversion manual, you can buy a smog check inspection manual from your local Bureau of Automotive Repair (BAR) office.
Return to “Datsun Chat”
